  • Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm
VisatonPart # 292-540
Model: K50WP - 16
Choose the 16 ohm 2917 K50WP 2" full-range speaker from Visaton for outdoor applications where direct moisture, high humidity, and space limitations are a factor.
  • IP65 rated speaker for outdoor use
  • UL 94-rated ABS basket
  • One-piece mylar cone and surround
Your Price: $7.59
MSRP: $9.99
Save $2.40 (24%)
Quantity:Qty: 1-9 $7.59/ea
Quantity:Qty: 10-24 $7.39/ea
Quantity:Qty: 25+ $7.10/ea
We'll send you an email when Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm is back in stock or available for preorder.
Estimated back in stock 1/16/2026
Visaton's 2917 K50WP 2" full-range speaker features a unique weather and UV-resistant design. A UL 94-rated ABS basket is used in conjunction with a one-piece mylar cone and surround. This allows the K50WP to be used in outdoor audio applications where water and high humidity are a factor. When used in a sealed enclosure, the front of this speaker conforms to the IP65 water resistance rating (meaning it can withstand direct moisture).
Note: For maximum power handling, a 1st-order 300 Hz high-pass filter is recommended.
BrandVisaton
ModelK50WP - 16
Part Number292-540
Weight0.119
Nominal Diameter2"
Power Handling (RMS)2 Watts
Power Handling (MAX)3 Watts
Impedance16Ω
Frequency Response180 to 17,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter0.39"
Resonant Frequency (Fs)300Hz
Maximum Linear Excursion (Xmax)0.25mm
Cone MaterialPoly / Mylar Diaphragm
Overall Outside Diameter1.97"
Baffle Cutout Diameter1.81"
Depth0.63"
