  • Visaton FRS8-8 3.3" Full-Range Speaker 8 Ohm
VisatonPart # 292-524
Model: FRS8 - 8
Choose the 2004 FRS8 3.3" full-range speaker from Visaton for sound applications where space is critical and high fidelity, full-range sound is needed. 8 ohm impedance.
  • 8-ohm impedance for most audio applications
  • Rugged, compact design with rubber surround and steel frame
  • Smooth, linear frequency response from 200 to 20 kHz
Your Price: $18.15
Save $2.84 (14%)
7 In Stock
We'll send you an email when Visaton FRS8-8 3.3" Full-Range Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 2 hr 6 min to ship today. Details
Visaton's 2004 FRS8 8 ohm, 3.3" paper cone HiFi full-range driver features smooth frequency response from 200 to 20,000 Hz, making it an ideal speaker for use in surround sound satellite speakers, multimedia speakers, exhibit display speakers, even ceiling speakers!
A rugged stamped-steel frame ensures durability, as does the rubber surround. With up to 50 watts of peak power handling and wide dispersion, the 2003 FRS8 might be one of the best values in the speaker industry.
BrandVisaton
ModelFRS8 - 8
Part Number292-524
Weight0.653
Nominal Diameter3"
Power Handling (RMS)30 Watts
Power Handling (MAX)50 Watts
Impedance8Ω
Frequency Response100 to 20,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)120Hz
DC Resistance (Re)7.2Ω
Voice Coil Inductance (Le)0.9mH
Mechanical Q (Qms)4.85
Electromagnetic Q (Qes)1.32
Total Q (Qts)1.04
Compliance Equivalent Volume (Vas)0.03ft³
Maximum Linear Excursion (Xmax)0.25mm
Cone MaterialPaper
Overall Outside Diameter3.07"
Baffle Cutout Diameter2.8"
Depth1.37"
Sealed Volume0.08ft³
Sealed F3109.4Hz
Vented Volume0.08ft³
Vented F383.8Hz
