  • Visaton BG17-8 6.5" Full-Range Speaker with Whizzer Cone 8 Ohm
VisatonPart # 292-546
Model: BG17 - 8
Visaton's 3017 BG17 full-range 6.5" dual-cone speaker offers great frequency response and sensitivity in a compact package. Great for point-source, single-driver speakers.
  • High sensitivity design
  • Treated paper accordion surround
  • Whizzer cone for time-aligned highs
  • Great for distributed audio and open baffle speakers
Your Price: $29.10
Save $1.89 (6%)
52 In Stock
We'll send you an email when Visaton BG17-8 6.5" Full-Range Speaker with Whizzer Cone 8 Ohm is back in stock or available for preorder.
The 3017 BG17 full-range speaker from Visaton is designed with a relatively flat frequency response and high output, using a paper cone with whizzer cone and treated paper accordion surround. Typical applications for the BG17 include: small stage monitor, 70V and 100V distributed audio systems (with provisions for transformer mounting built-in), full-range open baffle speakers, or as an instrument speaker for guitars, keyboards, and organs.
BrandVisaton
ModelBG17 - 8
Part Number292-546
Weight1.7
Nominal Diameter6-1/2"
Power Handling (RMS)40 Watts
Power Handling (MAX)60 Watts
Frequency Response80 to 20,000Hz
Sensitivity93dB 2.83V/1m
Voice Coil Diameter0.79"
Resonant Frequency (Fs)120Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.7mH
Mechanical Q (Qms)2.94
Electromagnetic Q (Qes)0.98
Total Q (Qts)0.74
Compliance Equivalent Volume (Vas)0.29ft³
Maximum Linear Excursion (Xmax)1.5mm
Cone MaterialPaper
Surround MaterialTreated Paper
Overall Outside Diameter6.5"
Baffle Cutout Diameter5.75"
Depth2.24"
Sealed Volume0.5ft³
Sealed F3133.7Hz
Vented Volume0.63ft³
Vented F393.22Hz
