  • USB 4.0 M/M Cable USB-C to USB-C 240W 40 Gbps 4K 3.3 ft. (1m)
Parts ExpressPart # 130-659
Enjoy up to 40 Gbps transfer rate, 8K video, and 240W of charging power with this USB-C 4.0 cable. USB 4.0 Type-C cable is the best solution for charging your USB Type C-base devices and syncing data, photos, video, and music.
  • Support video displays resolution up to 8K and data transfer rate of 40 Gbps
  • Single video 8K @ 60Hz, 4K @ 120Hz, or dual 4K @ 60Hz resolution for versatility
  • Sync while charging your USB Type-C equipped device with up to 240W
  • Backward compatible with all predecessors including USB 3.2, 3.1, 3.0, 2.0, and 1.1
  • USB 4.0 PCBA with ETRON chip, support EPR, Gen3
  • Compatible with various operating systems on mobiles or desktops
  • Support all USB 4.0 communications and features
Your Price: $14.98
Save $10.01 (40%)
We'll send you an email when USB 4.0 M/M Cable USB-C to USB-C 240W 40 Gbps 4K 3.3 ft. (1m) is back in stock or available for preorder.
Estimated back in stock 11/27/2026
USB 4.0 is only available in the USB-C format. This is good news since it has a reversible plug, small size and is built-in to most laptops, tablets, and newer smartphones. It has incredible 40 GBPS transfer rate, 8k video and 240W of charging power. Down load photos in seconds instead of minutes. Charge smartphones, with the right PD charger, in minutes instead of hours, and enjoy picture perfect 8k @ 60 Hz or 4K @ 120 Hz. The 0.48" W x 0.25" H slim shell fits in most smartphones even with the case on.
The 3.3 ft. (1m) cable and 240W power enables you to use and fully charge the phone/tablet/laptop at the same time in minutes with the right PD charger.
Part Number130-659
UPC848864074634
Weight0.1
Cable Length3.3feet
Cable TypeUSB C Male to C Male
Jacket ColorBlack
