  • 15W Ultra Slim Fast Wireless Charging Pad with 3 ft. USB-C to A Cable
CLEARANCE 15W Ultra Slim Fast Wireless Charging Pad with 3 ft. USB-C to A Cable
Parts ExpressPart # 125-385
Fast charge your smartphone with this 15W Qi compatible wireless charger. Its small LED charge indicator works perfect for bedside charging.
  • Wireless charging disc works through thick cases like OuterBox Defender
  • Includes 3 ft. 10W USB-C to USB-A cable for convenience
  • Small LED indicator for soft nighttime charge status notification
  • 15W Qi compatible for fast charge mode
  • Slim profile makes it almost invisible
  • Perfect end table charging station for guest
CLEARANCE $5.40
Save $14.59 (73%)
208 In Stock
We'll send you an email when 15W Ultra Slim Fast Wireless Charging Pad with 3 ft. USB-C to A Cable is back in stock or available for preorder.
This charger works perfect for all-night, bedside charging or end tables for guest to wirelessly charge they're smartphones. Plug the included USB-C to USB-A cable into any USB-A 2A wall charger (sold separately) for overnight charging. You'll notice a small red LED light up to signify power. Place the center of your smartphone that accepts Qi technology onto the plus sign of the small disc and the LED changes to blue. Both lights are very dimly lit preventing any extra distraction while you sleep. Your smartphone also displays that it's charging and changes to 100% when it's done. If the charging light doesn't change to blue gradually keep sliding your smartphone over the rubber plus sign until the light changes to blue or your smartphone displays charging. The wireless charging disc has rubber feet on the bottom to keep it from sliding off the nightstand. The wireless charging disc works through most smartphone cases which enables you to leave your case on. Some cases have metal built into the back which prevents wireless charging.
To fast charge your smartphone you'll need a USB 3.0 cable (sold separately) along with a QC3.0 USB-A or USB-C 20W PD wall charger (sold separately). These wall chargers along with the wireless disc adjust to the fastest charge rate your smartphone is made for. The wireless charging disc accepts a USB-C cable which most new Android based phones come with.
Specifications: • Input voltage: DC 5V/2A, 9V/1.67A, 12V/1.5A • Output current: 15W Max. • Material: ABS • Color: Black • Dimensions: 3.94" x 0.26" (100 x 6.5 mm).
Part Number125-385
UPC848864066714
Weight0.2
Center/Tip PolarityUSB
DC Output Voltage5V
Plug SizeUSB
