CLEARANCE Timpano Audio TPT-T3500-12 D2 12" Cast Frame DVC Subwoofer 2 Ohms Per Coil
Timpano Audio’s TPT-T3500-12 D2 12” high excursion subwoofer is designed to deliver extreme low frequency extension and maximum SPL. Featuring incredible linear excursion, top-grade soft parts, American made 3” voice coil, and a colossal cast aluminum basket, this driver sets a standard for powerful output and reliability. The TPT-T3500-12 D2 is the perfect choice for high power SPL competition systems, or just disturbing the peace in general.
- American made 3” flat wire voice coil can handle up to 1,750 watts RMS (3,500 max)
- 29 mm Xmax to move the massive amounts of air needed for extreme SPL
- Rigid cast aluminum frame designed for high excursion and extensive cooling
- Powerful triple stacked motor includes ample venting to dissipate unwanted heat
- Large diameter double layer spider with stitched tinsel leads improves reliability
Dayton Audio MX12-22 12" Max-X High Excursion DVC Subwoofer 2 Ohms Per Coil
Price: $184.98Part # 295-166
Dayton Audio UMII12-22 Ultimax II 12" DVC Subwoofer 2 Ohm Per Coil
See all items in Car Subwoofer SpeakersPrice: $224.98Part # 295-712
We'll send you an email when Timpano Audio TPT-T3500-12 D2 12" Cast Frame DVC Subwoofer 2 Ohms Per Coil is back in stock or available for preorder.
