  • Timpano Audio TPT-HL14-50 Slim 2" Aluminum Shallow Mount Horn 4-Bolt
Timpano AudioPart # 294-3344
Model: TPT-HL14-50 SLIM
Timpano Audio's TPT-HL15-50 Slim shallow mount horn is the only option when you need the absolute highest efficiency and output but have little room to spare. At only 2.59" deep this aluminum exponential horn makes it easy to mount 2" compression drivers in difficult spots like car doors and trunk lids.
  • Extremely shallow design to mount 2" compression drivers in little depth
  • Aluminum construction easily supports the weight of large compression drivers
  • Short throw with wide dispersion to easily fill a space with sound
  • Standard 4-bolt mounting flange is ideal for many popular drivers
  • An excellent match for the Timpano TPT-D3200TI-ND
Your Price: $24.95
Save $6.24 (20%)
We'll send you an email when Timpano Audio TPT-HL14-50 Slim 2" Aluminum Shallow Mount Horn 4-Bolt is back in stock or available for preorder.
Order in the next 3 hr 56 min to ship today. Details
If you want the absolute maximum SPL and have little space to work with, then Timpano Audio's shallow TPT-HL15-50 Slim 2" horn is what you need. At only 2.59" deep, this 2" throat horn makes it easy to install the highest efficiency 2" compression drivers in tight spots like car doors and trunk lids. With cast aluminum construction and a 4-bolt flange, the TPT-HL15-50 Slim can support the weight of today's massive 2" compression drivers. This exponential horn is designed to provide an extremely wide dispersion to minimize beaming and directivity.
Specifications: • Horn type: Exponential • Throat diameter: 2" • Mounting type: 4-bolt • Dimensions: 6.1" H x 6.1" W x 2.59" D • Cabinet cutout: 4" dia.
BrandTimpano Audio
ModelTPT-HL14-50 SLIM
Part Number294-3344
UPC611056238714
Weight1.2
ConstructionAluminum
Entry / Throat Diameter2"
Mounting Type4-Bolt
