  • Tang Band W8-2022 8" RBM Subwoofer 8 Ohm
CLEARANCE Tang Band W8-2022 8" RBM Subwoofer 8 Ohm
Tang Band
Part #264-955
Tang Band
Part #264-955
Model: W8-2022
The W8-2022 8" subwoofer from Tang Band offers class-leading low distortion performance, down to 25 Hz, due to its use of RBM dual surround technology.
  • High power handling in a shallow sub design
  • Patented dual cone, dual surround subwoofer
  • Ultra-linear operation for low non-linear distortion
  • Huge 3" voice coil with 8 mm of Xmax and extensive cooling
Tang Band designed their revolutionary RBM (Real Balanced Mode) flat subwoofers for ultra-linear operation, while remaining as thin as possible. The secret to their low distortion performance is in the patented symmetrical suspension system.
While most subwoofers rely upon a spider/surround combination to keep the cone travel linear, Tang Band has developed a new injection molding process that incorporates front and rear cones, as well as dual opposed surrounds.
Similar to an isobaric subwoofer alignment, the two cones work together to modulate a single column of air, reducing non-linear harmonic distortion. The added mass of the rear cone/surround assembly also reduces free air resonance.
Tang Band's W8-2022 8" RBM flat panel subwoofer features extensive venting on the rear cone, voice coil former, and back plate to keep the large, overhung, 3" voice coil cool. A bumped back plate allows for momentary moments of over-excursion without damage. Additionally, it offers low distortion frequency response that reaches down to 25 Hz.
BrandTang Band
ModelW8-2022
Part Number264-955
UPC848864015088
Weight16.3
Nominal Diameter8"
Bolt Circle Diameter9.84
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response25 to 1,000Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)25Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)0.21mH
Mechanical Q (Qms)5.24
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)1.11ft³
BL Product (BL)15.77T·m
Maximum Linear Excursion (Xmax)8mm
Surface Area of Cone (Sd)230cm²
Cone MaterialPoly Composite
Overall Outside Diameter9.61" across the flats, 10.38"
Baffle Cutout Diameter9.05"
Depth4.28"
Sealed Volume0.33ft³
Sealed F352Hz
Vented Volume0.77ft³
Vented F329Hz
