NEW Tang Band W4-2414 F Series 4" Full-Range with Phase Plug 8 Ohm
The Tang Band W4-2414 is a 4″ full-range driver engineered to deliver wide bandwidth from a single compact speaker. Its aluminum-reinforced composite cone and precision motor design support extended high-frequency response and very low distortion, making it suitable for high-performance full-range loudspeaker systems.
- Full-range driver design reproduces a wide bandwidth from a single speaker for simpler crossover-free systems
- Frequency response 65 Hz–40 kHz supports deep bass extension and extended high-frequency detail
- Aluminum alloy bullet phase plug improves high-frequency dispersion and extension
- Aluminum-reinforced polypropylene cone improves stiffness for cleaner, more controlled response
- Extremely low harmonic distortion design (≤0.01%) supports accurate, detailed sound reproduction
NEW $94.80
We'll send you an email when Tang Band W4-2414 F Series 4" Full-Range with Phase Plug 8 Ohm is back in stock or available for preorder.
