NEW Tang Band W3-2345S 3" Mini Subwoofer 4 Ohm
The Tang Band W3-2345S is a compact 3" subwoofer built for small speaker systems that need low-frequency output from a space-saving driver. Its long-throw design, aluminum diaphragm, and neodymium motor make it a practical option for compact subwoofers, portable speakers, desktop audio, and other space-limited designs.
- 7.7 mm Xmax for strong output from a 3" driver
- 45 Hz free-air resonance supports compact low-frequency designs
- Aluminum diaphragm helps transfer heat away from the voice coil
- Rubber surround supports controlled cone movement
- Neodymium magnet keeps size and weight low
- Patented structure design for compact subwoofer applications
We'll send you an email when Tang Band W3-2345S 3" Mini Subwoofer 4 Ohm is back in stock or available for preorder.
