  • Talent TWUH1 Wireless UHF Handheld Microphone System
Talent Sound & LightingPart # 233-400
Model: TWUH1
The Talent TWUH1 wireless handheld microphone system provides the freedom of wireless while retaining top notch audio quality. The crystal clear 48 kHz audio sampling rate provides incredible vocal clarity while the extended transmission range of 190 ft. gives you the freedom to move about the stage as you please. The wireless mic system includes one receiver and one handheld dynamic microphone.
  • Handheld wireless microphone system with 48kHz audio sampling rate providing clear, pristine, vocal clarity
  • 16 pre-set selectable frequencies ensure clean transmission
  • Digital ID code helps eliminate RF interference
  • IR sync automatically syncs the transmitter and receiver's carrier frequency without the hassle of RF management
  • Transmission range of up to 197 ft. for freedom of movement
  • Ideal for concerts, schools, clubs, and houses of worship applications
  • System includes one channel receiver, one wireless microphones, one 1/4" audio cable, one receiver power supply, two AA batteries
Talent TWUH2 Wireless UHF Dual Handheld Microphone System
Price: $169.98Part # 233-402
See all items in Handheld Microphone Wireless Systems
Your Price: $84.98
Save $24.01 (22%)
We'll send you an email when Talent TWUH1 Wireless UHF Handheld Microphone System is back in stock or available for preorder.
The Talent TWUH1 wireless handheld mic system allows you to move freely around your performance space while sounding great. Using a 48 kHz audio sampling rate, the TWUH1 delivers a crystal clear vocal clarity which will help your vocals be front and center whether for a presentation, live performance, or Emceeing events.
Using a simple to use, plug-and-play IR sync function, the TWUH1 is easy to get up and running. The IR sync automatically syncs the transmitter and receiver's carrier frequency without needing to worry about increasingly complicated RF management. With 16 frequencies available the TWUH1 provides you with enough carrier frequency options to ensure clean transmission signals. In addition, the wireless system features Digital ID code that helps eliminate unwanted RF interference.
Freedom of movement on stage is essential to wireless systems, the TWUH1 gives you a line-of-sight transmission range of up to 190 ft. (60 meters). With an extended transmission range and high performance sound quality, the TWUH1 is ideal for concerts, schools, clubs, and houses of worship.
Receiver specifications: • Operating frequency: UHF 918.80 - 927.80 MHz • Sampling rate: 48 kHz • Latency: 3ms • Dynamic range: >96 dB • THD: <0.2% • Frequency response: 30 - 18,000 Hz • SNR: >96 dB • Receiving sensitivity: -94 dBm • Audio output level: 400 mV unbalanced, 400 mV balanced • Power supply: 12 VDC / 1A • Dimensions: 8.07" x 4.52" x 1.45".
Transmitter Specifications: • Transmitter power: 10mW • Harmonic radiation: <-50 dBc • Range: up to 60 meters (197 ft.) • Frequency selection: IR sync • Microphone type: Dynamic • Microphone casing: Aluminum / anodic oxidation • Battery voltage: 3V (2 x 1.5V AA batteries) • Battery life: Continuous usage > 8 hours • Dimensions: 10.12".
BrandTalent Sound & Lighting
ModelTWUH1
Part Number233-400
UPC848864044576
Weight2.55
Frequency BandUHF
