Talent SSL2 RGBW LED DMX Mini Moving Head Stage Light 7 x 10WTalent Stage and Lighting engineers and delivers outstanding products used in both consumer and professional applications. With a reputation of providing high-quality, budget-friendly products, Talent has once again delivered on achieving professional-grade lights at a fraction of industry-standard pricing
Virtually Unlimited Color Mixing
Utilizing seven bright 10-watt 4-in-1 RGBW LEDs, the Talent SSL2 moving head light delivers a dazzling 70 watts of illumination ready for stage performances of all sorts. The workhorse light is capable of producing a wide range of rich and vibrant multi-color mixing so no matter your application the perfect colorful ambiance awaits you.
Even when producing enough power to light up stages and event spaces, the SSL2 runs extremely efficiently, thus reducing electrical power draw. The LEDs stay cool temperatures so the performer can step into the spotlight without suffering from fixture-generated heat.
Versatile Controls
Not only is the SSL2 fully DMX 512 compatible, but the light also features built-in programs, master/slave functionality, and sound-activated lighting shows. Featuring both 9 and 14 channels of DMX, you have free access to the light's functions right from your DMX controller. Control over pan, tilt, and movement speed allows you to program the perfect lighting show with DMX commands as well as internal programming features. Built-in auto and sound-activated internal lighting programs provide stunning lighting shows without the need to pre-program the light.
Professional grade motors deliver rugged reliability for pan and tilt movements so that your shows remain uninterrupted. Fine-tune dimming, strobe, motor speed, and maximum pan and tilt for smooth, realistic lighting movements.
The Light Your Rig Needs
Whether you are a professional touring lighting director or a mobile entertainer, the SSL2 adds a flexible option for creating vivid, dazzling light shows. Perfect for professional rigs, clubs, houses of worship, mobile entertainers, and event centers, the SSL2 delivers high-power, professional light fx at budget-friendly pricing. Find how Talent will add a splash of color to your gigs with the SSL2.
Note: DMX cable not included
LEDS: 7 x 10W 4-in-1 RGBW
DMX channels: 9/14
Modes: DMX512, master/slave, sound active, auto
Beam angle: 25°
Strobe: 1-25 flashes per second with pulse effect
Pan: 540°, 360°, 180°
Tilt: 270°, 180°, 90°
Program presets: 8 built-in, controlled via DMX
Lumen ratings: 1100 R, 1100 G, 1300 B, 2165 W, 5000 RGBW
Control panel: LED display
Control in/out: 3-pin DMX in / out connectors
Cooling system: Efficient, low noise fan
Power input: 100-240 VAC, 50/60 Hz
Power consumption: 80 Watts
Dimensions: 8.9" L x 8.9" W x 10.6" D
