  • Talent LS1 8 ft. Heavy Duty Tripod Lighting Stand
CLEARANCE Talent LS1 8 ft. Heavy Duty Tripod Lighting Stand
Talent Sound & LightingPart # 233-080
Model: LS1
Talent's LS1 lighting stand is built to perform and endure night after night, but is packed with features that make it super easy to use -- and it's super easy on the pocketbook! It's a win-win-win!
  • Air cushion suspension keeps lights from free falling during tear-down
  • Push-button auto-locking pin system -- no pins to lose!
  • Can also be used as a speaker stand
  • Sturdy 110 lb. capacity
We'll send you an email when Talent LS1 8 ft. Heavy Duty Tripod Lighting Stand is back in stock or available for preorder.
From the most intimate club to the largest ballroom, Talent lighting stands are rugged enough to handle life on the road. The air-cushion pneumatic suspension prevents your load from free falling during tear-down, which not only makes this stand safer, it combines with the auto-lock push-button locking pin system for quick, easy, and secure height adjustment. There is no loose locking pin dangling from the stand on a cord, which means your pin will never get lost in the shuffle (and they always do get lost, don't they?). Also gone are the days of trying to hold the stand in position with one hand, while you fumble around trying to grab and wrangle the locking pin into a tiny little hole with the other. Large ergonomic wingnut knobs are featured on all adjustment points.
The LS1 is manufactured using a 1-3/8" diameter aluminum center pole, which means it can pull double-duty as a great speaker stand when you need it to. The included 47" crossbar is pre-drilled and includes bolts, washers, and wingnuts to accommodate four light fixtures. All this plus the rugged steel legs and metal spreader adds up to a durable, high-strength stand that is capable of supporting lights (or a speaker) weighing up to 110 lbs. A 48" tripod base spread offers superior stability, and it all collapses down to a 54" length that's less than 5" in diameter for extreme portability. The black finish all but disappears on-stage, keeping the focus on you.
Specifications: • Center pole and crossbar diameter: 1-3/8" • Stand height: Adjustable from 55" to 97" • Fixed height positions: 55", 58", 61.5", 65.5", 69.5", 73.5", 77.25", 81.25", 85.25", 89", 93", 97" (measured to top of center pole; crossbar adds approximately 1") • Tripod base spread: 48" • Collapsed length: 54" • Finish: Black • Weight capacity: 110 lbs. • Sold individually.
BrandTalent Sound & Lighting
ModelLS1
Part Number233-080
UPC848864007038
Weight14.95
