  • Talent All-In-One Recording Bundle -- Vocal Booth - USB Mic - Shock Mount - Pop Filter - Mic Stand
CLEARANCE Talent All-In-One Recording Bundle -- Vocal Booth - USB Mic - Shock Mount - Pop Filter - Mic Stand
With the All-In-One home recording bundle from Talent, anyone can really be a star without leaving the comfort of home! You get a high quality, plug and play USB microphone with a shock mount pop filter, and proper mic stand, as well as a portable isolation booth to make sure your recordings sound just like the pros!
  • Everything you need to get started recording in one simple package
  • Includes USB microphone, USB cable, isolation booth, shock mount, pop filter
  • Proper heavy duty mic stand to support the vocal booth and mic
  • All for less than the price of one typical USB mic!
The new All-In-One home recording package from Talent Sound & Lighting gives you an awful lot of oomph, at a price you won't believe. You get a mini vocal booth, USB mic with cable, shock mount, pop filter, even a mini tripod stand for desktop use -- all for under 100 bucks?! Yes. All for under 100 bucks!
The USB-1 microphone offers a super-simple plug and play solution to recording at home (or on the go with your laptop), and it sounds frickin' awesome! No expensive preamps and/or interfaces to buy or hassle with. No drivers to install or be vexed by. Just plug it in to an open USB port, and BAM! You're ready to record in your favorite DAW or recording software. A tight cardioid polar pattern keeps the recording focused on your voice or instrument, rejecting ambient noise.
YouTubers, podcasters, vloggers, home recording buffs, and others will appreciate the attention to detail, quality, and simplicity of this package. The VB-1 mini portable vocal booth is already one of Talent's top-selling items, so adding a great sounding USB mic, pop filter, and more goodies makes it a no-brainer for anyone interested in computer-based recording or audio production of any kind.
Isolation Booth Specifications: • Overall dimensions: 19-1/4" (fully opened) to 5" (closed) wide, 12" high, 10" (closed) to 3-1/2" (fully opened) deep • Threads: 5/8"-27 TPI • Adapter dimensions: 5-7/8" long, 5-1/4" high • Adapter adjustable depth range: 1" to 5".
Pop Filter Specifications: • Overall diameter: 6" • Gooseneck length: 11-1/2"
Microphone Specifications: • Element: 14 mm back electret condenser • Polar pattern: cardioid • Frequency response: 20 - 17,000 Hz • Sensitivity: -34 dB ± 2 dB (0 dB = 1v/Pa at 1 kHz) • Output impedance: 1000 ohms • Load impedance: 100 ohms (at 1 kHz) • Equivalent noise level: 16 dBA • Max. SPL: 132 dB (at 1 kHz, 1% THD) • S/N ratio: 78 dB • Works with Windows 2000/XP/Vista/7/8/10/Mac OS systems without installing driver.
Mic Stand Specifications: • Stand height: 9.1" - 14.2" • Finish: Powder-coated black.
NOTE: The bundle does not include any software; however, many great software recording solutions are available for little or no cost online. We recommend Audacity as a free, easy, and effective recording program.
BrandTalent Sound & Lighting
Part Number233-091
UPC848864057170
Weight9
