  • Talent MIX-R 3-Channel 4-In 2-Bus Compact Portable Stereo Mixer with USB Audio & +20V Phantom Power
Talent Sound & LightingPart # 233-120
Model: MIX-R
Talent knows what musicians want, and they've hit another home run with the MIX-R 4-input 2-bus portable mixer. XLR and 1/4" input? Check. RCA stereo inputs? Check. USB interface for computer-based podcasting & recording? Check. All the features you need, at a price you can afford.
  • Top quality mic preamp + phantom power
  • XLR, 1/4", and RCA inputs
  • USB interface for recording & podcasting
  • Great sound quality, super simple to use
Your Price: $49.88
MSRP: $109.99
Save $60.11 (55%)
We'll send you an email when Talent MIX-R 3-Channel 4-In 2-Bus Compact Portable Stereo Mixer with USB Audio & +20V Phantom Power is back in stock or available for preorder.
Order in the next 0 hr 47 min to ship today. Details
The Talent MIX-R professional, portable USB-based mixing console was designed for musicians on the go. It is perfect for computer-based recording and podcasting duties, and much smaller than a big, clunky standard mixing console. Connect the MIX-R to the USB port of your computer, and it functions as your computer's sound card over the second input. A combination XLR - 1/4" connector provides channel one's microphone or line input. Channel two can be fed from your choice of stereo RCA inputs or USB from your computer. RCA and 3.5 mm stereo outputs are available for monitors or headphones. Channel one includes an ultra-low noise mic preamp with +20V phantom power and gain control; both channels feature 2 band EQ for lush and natural sound quality. A signal-clip LED is present on channel one, as well as L+R clip indicators for the main output.
Specifications: • Frequency response: 10 - 40,000 Hz • THD/N: 0.01% • Mic EIN: -118 dBu • Input gain: 0 to 50 dB (mic); -35 to +15 dB (line) • USB ADC & DAC: 16-bit Delta-Sigma; 44.1 kHz sampling rate • System requirements: Windows 2000, XP or higher; Mac OS 9.0.4, 10.X or higher • Dimensions: 4" x 6" x 1.5" • Powered by USB connection or 5 VDC 500mA adapter (included).
BrandTalent Sound & Lighting
ModelMIX-R
Part Number233-120
UPC848864007632
Weight1.35
Mixer TypeAnalog
XLR Mic Inputs< 6
Special FeaturesUSB Connectivity
