  • Talent AM150 Active PA Monitor Speaker 150W 3-Ch Mixer with EQ and Echo Effect
CLEARANCE Talent AM150 Active PA Monitor Speaker 150W 3-Ch Mixer with EQ and Echo Effect
Talent Sound & Lighting
Part #233-210
Model: AM150
Talent's AM150 powered monitor is small and light enough to go just about anywhere as a monitor, but powerful and clear enough to also be used as a PA speaker for intimate venues, small speaking engagements, and more. You get 3 input channels, echo FX on 1 or 2 channels, and a master 3-band EQ on the 150-watt output.
  • Very versatile 150W powered monitor
  • Lightweight but powerful Class-D amp technology
  • 3 input channels for mics, instruments, and media
  • Channel one can be optimized for instruments, no DI box needed
  • Great for singers, keyboardists, drummers, presenters, DJs
Say goodbye to schlepping around heavy floor wedges and amps or bulky powered monitors, and say hello to the 21st century with Talent's AM150 active monitor speaker!
The AM150 uses a Class-D amplifier to provide 150 watts of power to the 5" full-range speaker for loud and clear sound quality, while keeping overall weight to a minimum - only about 6 pounds. Three input channels with a built-in mixer makes the AM150 more than just a simple monitor. Channel 1 can be optimized at the press of a button for instrument input with no DI box required. Channels 1 and 2 both feature high-quality mic preamps, both will accept mic or line level signals, XLR or 1/4" balanced or unbalanced, and both can provide phantom power for condenser mics. Channel 3 accepts L/R RCA inputs or 3.5 mm stereo input so you can play background music for your presentation or breaks between sets. Word.
Multiple AM150s can be linked together as well, using the MAIN IN and THRU XLR jacks on the back of the cabinet. This allows AM150s to be daisy-chained, so you can use one as a monitor, then add more AM150s as main PA speakers for small rooms, speaking engagements, singer/songwriter coffeehouse gigs, and the like.
Another great feature of the AM150 is the Echo (delay) effect which can be applied to channel 2 only, or to channels 1 and 2. Add some pizazz to your karaoke performance, just a little, or a lot - and once again - without more gear to schlep!
The small size and light weight of the AM150 allows it to go where conventional monitors simply cannot. Like, on your mic stand! An extension rod is included, so you can mount a standard mic boom to the top of the AM150, and have one less stand to worry about. If you do need a great stand, see Related Products below. The AMT tripod stand is sold separately, designed specifically for the AM150, and includes a boom arm. Or, you can get the bundle which includes the AM150 and AMT, and save some cash.
NOTE: The AM150 will slip right on to many standard straight mic stands (you may need to remove the jamb nut if your stand has one). It includes a pole mount with a 3/8"-16 threaded insert for Euro-style stands. To use the pole mount with a US-style 5/8"-27 stand, pick up our part number 233-039, the Talent MSA2 thread adapter.
Specifications: • Output power: 125W RMS, 150W peak • Channel 1/2 input: XLR/TRS combo jack, balanced or unbalanced • Channel 3 input: RCA x 2, 3.5 mm stereo, unbalanced • Frequency response: 20 - 20,000 Hz (± 3dB) • Max SPL: 114 dB @ 1m • Dimensions: 7-1/2" H x 11-1/4" W x 6-3/4".
BrandTalent Sound & Lighting
ModelAM150
Part Number233-210
UPC848864039442
Weight8.8
ConfigurationStage Monitor
Speaker TypeActive / Powered
Woofer Size5"
