  • Switchcraft E3FSC 3 Pin XLR Connector Female Panel Silver Pins
SwitchcraftPart # 093-326
Model: E3FSC
The E3FSC 3-pin XLR female panel mount connector has a die-cast zinc shell with nickel finish and silver plated contacts.
  • Both male and female fit in same panel cutout
  • Locking receptacles
  • Protected ground clip minimizes scooping damage
  • Insert lock detent resists disassembly from shock or vibration during handling and transportation
See all items in XLR Connectors
Your Price: $5.29
MSRP: $9.75
Save $4.46 (46%)
137 In Stock
We'll send you an email when Switchcraft E3FSC 3 Pin XLR Connector Female Panel Silver Pins is back in stock or available for preorder.
Switchcraft's E Series offers a panel mount with quick release inserts. A small screwdriver is used to remove the inserts, allowing for easy gender changes. The male and female E Series fit in the same panel cut-outs. The E3FSC 3-pin XLR female panel mount connector has a die-cast zinc shell with nickel finish and silver plated contacts. Package includes two #4-40 machine screws for mounting into panels with 4-40 tapped holes, such as the Switchcraft QG® Series.
BrandSwitchcraft
ModelE3FSC
Part Number093-326
UPC844632071966
Weight0.1
Conductors3-Pin
GenderFemale
