  • Sure Electronics AA-AB32281 2x200W Class D Audio Amplifier Board - T-Amp
CLEARANCE Sure Electronics AA-AB32281 2x200W Class D Audio Amplifier Board - T-Amp
Sure ElectronicsPart # 320-3364
Model: AA-AB32281
Design your own powered subwoofer, powered speaker or audio amplifier with Sure's 2 x 200 watt stereo amp board. It's small in size, but ready to handle mid power demanding audio projects.
  • Temperature controlled cooling fan
  • Over-engineered protection circuits
  • Versatile 3-ohm stability
  • Perfect size for use as a subwoofer amplifier for home or vehicle
  • Up to 400 watts max power
  • Requires 15 to 36 VDC power supply
  • 4-screw in standoffs for easy installation
We'll send you an email when Sure Electronics AA-AB32281 2x200W Class D Audio Amplifier Board - T-Amp is back in stock or available for preorder.
This mid power stereo amplifier board means serious business! This audio amplifier board cranks out 400 watts of power using Sure Electronics T-AMP technology, featuring low distortion and low noise level. For do-it-yourselfers, looking for an audio amp for your home or vehicle.
Temperature controlled cooling fan, as well as protection circuits to protect against over/under voltage, over current, short circuit, and over temperature conditions are built-in for years of enjoyment. This amp board has three fixed gain settings or you can use Sure's plug in volume control option. A 15 to 36 VDC power supply is required.
Note: The minimum recommended wire gauge to be used for power is 16 AWG.
• Power output (w/ 36 VDC power supply): 100W x 2 (3 ohms, THD 10%), 64W x 2 (3 ohms, THD 1%)
• Minimum impedance: 3 ohms
• Frequency response: 20 to 20,000 Hz (±3 dB)
• SNR: 94 dB (128W @ 3? THD+N 1%)
• Recommended power supply: 15 to 36 VDC, 12.6A regulated
• Fixed gain settings: 24, 26, 28 dB
• Power input jack: 2.5 x 5.5 mm, center-positive
• Dimensions without RCA jack: 4.8" L x 3.6" W x 1.53" H
BrandSure Electronics
ModelAA-AB32281
Part Number320-3364
Weight0.93
Board Type2 Channel Stereo Amp
Power (RMS/Channel 8 ohms)51 - 100 Watts
