  • Parts Express 80 Hz High Pass 4 Ohm Crossover
Parts ExpressPart # 266-456
Convenient crossovers that work great in any application requiring economical, flexible filtering.
Your Price: $22.99
Save $7.00 (23%)
40 In Stock
We'll send you an email when Parts Express 80 Hz High Pass 4 Ohm Crossover is back in stock or available for preorder.
Convenient crossovers that work great in any application requiring economical, flexible filtering. Also for use in car stereo installations with component speaker systems. Low pass, band pass, and high pass models complement woofers, midranges, and tweeters. Designed to be wired in-line between amp and speaker by using .205" disconnect terminals or soldering. The crossovers' compact size facilitates mounting virtually anywhere you desire.
Specifications: • Approximately 250 watts RMS • Type: High pass • Driver impedance: 4 ohm • Crossover frequency: 80 Hz • Roll off: 12 dB.
Part Number266-456
UPC844632074929
Weight0.75
Crossover TypeHigh Pass
