  • Sure Electronics AA-AB31316 1x400W Class D Audio Amplifier Board (T-Amp Technology)
CLEARANCE Sure Electronics AA-AB31316 1x400W Class D Audio Amplifier Board (T-Amp Technology)
Sure ElectronicsPart # 320-3344
Model: AA-AB31316
Design your own powered subwoofer or subwoofer audio amplifier with Sure's 400 watt mono amp board. It's size enables it to work with high power, low-profile subwoofers.
  • Perfect for use as a subwoofer amplifier for home or vehicle
  • Up to 400W of Class-D clean power
  • Versatile 1.5-ohm stability
  • Over-engineered protection circuits
  • Requires 24 to 36 VDC power supply
  • Robust heatsink with two-stage cooling fan
  • Click and pop noise reduction
Sure Electronics AA-AB31241 1x600W TAS5630 Class-D Amplifier Board
Price: $63.98Part # 320-311
See all items in Audio Amplifier Boards & Modules
We'll send you an email when Sure Electronics AA-AB31316 1x400W Class D Audio Amplifier Board (T-Amp Technology) is back in stock or available for preorder.
This mid power mono amplifier board means serious business! This audio amplifier board cranks out 400 watts of power using Sure Electronics T-AMP technology, featuring low distortion and low noise level. For do-it-yourselfers, looking for a subwoofer amp for your home or vehicle.
A robust heatsink, two-stage cooling fan, as well as protection circuits to protect against over/under voltage, over current, short circuit, and over temperature conditions are built-in for years of enjoyment. Three fixed gain settings allow you to match the amplifier to your source, and use your source as the volume control or Sure's plug in volume control option. A 24 to 36 VDC power supply is required.
Note: The minimum recommended wire gauge to be used for power is 16 AWG.
• Power output (w/ 36 VDC power supply): 400W x 1 (1.5 ohms, THD 10%), 294W x 1 (1.5 ohms, THD 1%)
• Minimum impedance: 1.5 ohms
• Frequency response: 20 to 20,000 Hz (±3 dB)
• SNR: 93 dB (294W @ 1.5? THD+N 1%)
• Recommended power supply: 24 to 36 VDC, 12A regulated
• Fixed gain settings: 28 dB, 30 dB, 32 dB
• Power input jack: 2.5 x 5.5 mm, center-positive
• Dimensions without RCA jack: 6" L x 4.5" W x 0.95" H
BrandSure Electronics
ModelAA-AB31316
Part Number320-3344
UPC848864053080
Weight1.35
Board Type1 Channel Mono Amp
Power (RMS/Channel 8 ohms)101 - 250 Watts
