  • Mean Well MW SE-450-36 36V 12.5A 450W AC/DC Switching Power Supply
CLEARANCE Mean Well MW SE-450-36 36V 12.5A 450W AC/DC Switching Power Supply
Mean WellPart # 320-3144
Model: SE-450-36
This large 36 volt DC, 12.5 amp regulated power supply is capable of up to 450 watts of output. Switchable 90-264 volts AC input. UL recognized design.
  • Adjustable 33 to 39 VDC regulated output with 12.5A current capacity
  • AC input active surge current limiting reduces AC noise
  • AC input range selected by switch for domestic and international applications
  • Overload, over voltage, and over temperature protection built-in
  • Forced air cooling by built-in DC ball bearing fan
  • Built-in remote sense function
  • UL 60950-1 approved for safety
CLEARANCE $71.17
MSRP: $152.99
Save $81.82 (53%)
1 In Stock
We'll send you an email when Mean Well MW SE-450-36 36V 12.5A 450W AC/DC Switching Power Supply is back in stock or available for preorder.
Order in the next 1 hr 1 min to ship today. Details
This beast of a power supply is ideally suited for use with amplifier projects. With a regulated output of 36 volts DC, and current capacity of 12.5A amps, this power supply is the perfect partner for amplifier boards with of up to 450 watts of output on tap.
Voltage input can be switched for use with 110 or 240 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Forced air cooling regulates temperature internally. Power cable included. UL recognized design. Output voltage is adjustable from 32 to 40 VDC.
Note: Minimum recommended power wire is 16 AWG.
Specifications: • Input power: Switchable between 90-132 VAC and 180-264 VAC, 47-63 Hz • Output power: 36 VDC, 12.5A • Dimensions: 8.85" L x 4.75" W x 1.97" H • Includes: 5 ft. AC cord and 3 ft. DC cord with 2.1 x 5.5 mm plug.
BrandMean Well
ModelSE-450-36
Part Number320-3144
Weight3.25
DC Output Voltage36V
Input Voltage110/220 VAC
