  • Soldering Iron Holder/Clamp with Metal Base
CLEARANCE Soldering Iron Holder/Clamp with Metal Base
Parts ExpressPart # 370-353
Say goodbye to burnt fingertips and hello to a different type of hands-free soldering. This amazing device's design securely holds your soldering iron, allowing you to work on wires, electrical components, PC boards, or any other item you need to solder without the fear of getting burned.
  • Versatile large Jaw
  • 3" x 4-1/4" metal base for stability
  • Tighten all the joints with one knob for ease of use
  • For rubber feet keeps it in place and absorbs shock
We'll send you an email when Soldering Iron Holder/Clamp with Metal Base is back in stock or available for preorder.
An Iron Holder That Let's You Solder
Now, you may be wondering how this soldering iron holder can make your DIY soldering projects easier. Well, imagine having both of your hands free to manipulate and position your components while the soldering iron remains safely secured. Tin wires and then solder them together without even touching the iron. It's like having an extra set of hands, allowing you to work with precision and confidence.
Versatile Large Jaw
One of the standout features of this soldering iron holder is its spacious jaw. Unlike similar helping hands, it can easily accommodate large PC boards, giving you the flexibility to work on projects of all sizes. The 3" x 4-1/4" metal base helps hold the 2" x 2" jaw securely in place. Just tighten the adjustment knob when the clamp is in position. One knob tightens all joints at the same time. The joints have the ability to extend up to 6" from the base. No more struggling to find a tool that can handle the size of your work - this holder has got you covered.
So, whether you are a seasoned soldering pro or just starting out on your DIY journey, this soldering iron holder is a must-have tool. Say goodbye to burnt fingers, embrace the convenience of hands-free soldering, and enjoy the freedom to tackle any project with ease.
Part Number370-353
UPC848864074948
Weight0.75
