  • Small Precision Electronic 5" Diagonal Wire Cutting Tool with Stripping Hole for 22-26 AWG Wire
CLEARANCE Small Precision Electronic 5" Diagonal Wire Cutting Tool with Stripping Hole for 22-26 AWG Wire
Parts ExpressPart # 360-843
Reach in to tight spaces with this 5" thin blade wire cutter/stripper. It provides superior shearing action with a smooth, flat, and clean finish. Perfect for cutting zip ties, preparing Ethernet cables, trimming excess leads on PC boards, jewelry making and any hobby that requires a full flush cut.
  • Sharp slender blades reach into tight spaces
  • Added small gauge wire stripping capability makes them more versatile
  • Textured soft plastic handles for better gripping action
  • Return coil spring action for convenience
  • Angled blades for cutting leads close to the surface on PC boards
  • Precision aligned 3/8" steel blades cut wires up to 18 AWG
CLEARANCE $5.98
MSRP: $9.99
Save $4.01 (40%)
100 In Stock
We'll send you an email when Small Precision Electronic 5" Diagonal Wire Cutting Tool with Stripping Hole for 22-26 AWG Wire is back in stock or available for preorder.
Use this 5" slim blade diagonal cutter to trim excess leads from electrical components and wires sticking out of PC boards. The angled 3/8" blades enable you to flush cut these unwanted leads close to the board. The small thin angled design allows you to reach into tight spaces to prevent having to remove the board from the enclosure in many cases.
Besides the thin design this diagonal cutter has an added feature that strips wires from 22 to 26 AWG. This works perfect for jobs that use telephone or Ethernet cables where punch down or crimping isn't an option.
Part Number360-843
UPC848864070803
Weight0.19
