  • SPST NO Momentary 22mm Stainless Steel Waterproof Touch Piezo Tamper Proof Switch with Red Ring 3-24 VDC
CLEARANCE SPST NO Momentary 22mm Stainless Steel Waterproof Touch Piezo Tamper Proof Switch with Red Ring 3-24 VDC
Parts ExpressPart # 060-661
This piezo SPST N.O. momentary touch switch has no moving parts to wear out and works perfect in low current applications. Its heavy duty stainless steel IP68 waterproof body has a built-in red indicator ring that lights up when activated.
  • Simple touch action with no mechanical parts to wear out
  • IP68 rating for extreme conditions
  • 3-24 VDC red ring lights up when activated
  • Mounts easily in a 7/8" (22 mm) hole
  • Includes a rubber ring to help seal out moisture
  • RoHS certified
CLEARANCE $11.86
MSRP: $27.99
Save $16.13 (58%)
66 In Stock
We'll send you an email when SPST NO Momentary 22mm Stainless Steel Waterproof Touch Piezo Tamper Proof Switch with Red Ring 3-24 VDC is back in stock or available for preorder.
Use this piezo touch switch in low current applications between 3 to 24 VDC under 100 mA. Its heavy duty stainless steel IP68 waterproof body and button has a built-in red indicator ring that lights up when activated. No moving parts or rust to worry about and has a life cycle up to 1,000,000. Drill a 7/8" hole for mounting and make sure you use the included rubber ring washer to meet the IP68 rating. Constant DC voltage needs to be suplied for the switch to work.
Specifications: • Current rating: 100 mA @ 3-24 VDC • Shaft diameter: 0.863" (22 mm) • Working temperature: -40° F to 158° F • Total dimensions without terminals: 0.81" L x 1.1" D (20.5 x 28 mm) • Lead wire gauge: 24 AWG • Lead wire length: Two 5.24" (133 mm) white contact and one 5.24" (133 mm) red hot and one 5.24" (133 mm) black ground • LED: Red 3V.
Part Number060-661
UPC848864059044
Weight0.03
CircuitSPST
IlluminationIlluminated
