  • SPST NO Momentary 16mm Stainless Steel Tamper/Waterproof Raised Push Button Switch with Blue Ring
CLEARANCE SPST NO Momentary 16mm Stainless Steel Tamper/Waterproof Raised Push Button Switch with Blue Ring
Parts ExpressPart # 060-950
Use this heavy duty, Stainless steel, anti-vandal, raised push button momentary switch for outdoor and other extreme condition applications. It has a built-in blue power/ring light for multiple applications.
  • Popular for use in kiosk applications, ticket dispensers, and industrial-type applications
  • Stainless steel body and IP67 rating for extreme conditions
  • Built-in 3V blue LED illuminating ring for low lit areas and connection identification
  • Easily mounts in a 5/8" hole with included shaft nut
  • 0.110" crimp/solder terminals for easy installation
  • RoHS certified
  • + and - symbols on the switch body for polarity identification for the built-in LED
We'll send you an email when SPST NO Momentary 16mm Stainless Steel Tamper/Waterproof Raised Push Button Switch with Blue Ring is back in stock or available for preorder.
This anti-vandal pushbutton switch is popular for use in kiosk applications, ticket dispensers and industrial-type applications. The stainless steel body and button stay looking great even with heavy duty use. The switch has an IP67 waterproof rating for extreme conditions indoors or outdoors when used with included rubber washer. This switch has a built-in 3V blue LED light for locating in low lit areas. Add a 390 ohm resistor for 12V or 5.6K resistor for 120V applications.
Specifications: • Contact: SPST N.O. momentary • Current rating: 3mA~5A • Switch voltage: 1.5V~250 VAC/DC • Blue LED voltage: 3V without any resistor • Switch total size with button raised without terminals: 0.75" L x 0.7" Dia. • Metal thread dimensions: 0.62" Dia. x 0.4" L • Button size: 0.35" Dia. • 4 terminals dimensions: 0.08" W x 0.17" L x 0.02" D
Part Number060-950
UPC848864066219
CircuitN.O.
IlluminationIlluminated
