  • Reiko TC100 2A USB Power Adapter 2-Port 5V Pink
BUYOUT Reiko TC100 2A USB Power Adapter 2-Port 5V Pink
Factory BuyoutsPart # 129-173
Model: TC100
Always have this intelligent Reiko dual 2.1A output USB charger with you wherever you go. It stops charging when your device is fully charged and it folds up to save space when traveling.
  • Prevents overcharging by syncing with your device to know when to stop charging
  • 2A output USB port for tablets and fast charging
  • 1A output USB port for low amperage Bluetooth devices
  • Blue LED power indicator lights up USB ports for night identification
  • 100~240 VAC 50/60 Hz input for international use
  • Space saving folding AC prongs
  • Unique pink color
BUYOUT $1.97
MSRP: $12.99
Save $11.02 (85%)
216 In Stock
We'll send you an email when Reiko TC100 2A USB Power Adapter 2-Port 5V Pink is back in stock or available for preorder.
The Reiko TC-100 delivers a super-fast and powerful charge from wall outlet to USB devices without the fear of overcharging. It syncs with your USB device and shuts off when charging is complete. It has separate ports for 2 amp and 1 amp USB charging devices so that you can charge two devices at once. It delivers up to 2.1 amps combined when charging two devices. For fast charging, only plug one device in at a time.
Folding AC prongs make the TC-100 the perfect size to fit in your pocket or small bag for the person on the go. Plus, it doesn't get tangled up with cords, or strings like other USB chargers and its AC input voltage lets you travel with it internationally.
Specifications: • Input voltage: 100~240 VAC 50/60 Hz • Max AC current draw: 0.3A • Output voltage: 5 V • Total output current: 2.1A.
BrandFactory Buyouts
ModelTC100
Part Number129-173
UPC885249518826
Weight0.16
Current Capacity2100mA
DC Output Voltage5V
Input Voltage100~240 VAC
