Rean RC3FR 3 Pole XLR Female Right-Angle Cable Connector The cup style terminals are designed to make soldering a breeze. With these terminals, you no longer have to worry about the solder shifting or moving while you work. Simply heat the solder that you've added to the terminal and insert the wire into the cup - it's that easy! This feature not only saves you time but also ensures a secure and reliable connection.
In addition to the convenient cup style terminals, these connectors also include an extra ground contact for optimal contact integrity between the chassis and cable connector. This means you can count on a strong and stable connection, reducing the chances of any signal loss or interference.
But it doesn't stop there! These connectors are built to last, thanks to their more durable housing. The increased reliability of the housing ensures that your connectors withstand even the toughest conditions, providing you with peace of mind and saving you from frequent replacements.
To top it off, the rugged diecast right-angle shell saves space by preventing the wire from sticking straight out. This not only adds to their aesthetic appeal but also enhances their functionality. The right-angle design is able to point the cable down, to the side, or up depending on your preference.
So, if you're looking for connectors that simplify the soldering process, offer excellent contact integrity, provide maximum reliability, and have a stylish design, look no further! You won't be disappointed!
Specifications: • Contacts: Silver plated brass • Body: Nickel plated zinc • Rear screw on plastic body: PA6+30%GF UL94-HB • Termination style: solder • Entry hole: 4-7 mm • Shell dimensions: 3" L x 1" Dia. • Connector dimensions with shell: 1-1/2" L x 3/4" Dia.
REAN — a brand of Neutrik AG
