22/2 Shielded Mic/Line Cable with Drain Wire 100 ft.
ConsolidatedPart # 101-650
Popular interconnect cable suits a variety of audio applications. Ideal for balanced/unbalanced line level audio, as well as permanently installed microphone connections under floors, in walls, or in racks.
- Industry-standard 22 AWG two-conductor wire
- For balanced or unbalanced audio applications
- Flame retardant gray PVC jacket, VW-1 and UL listed for safety
- Annealed stranded tin copper conductors (7/30 per conductor) deliver excellent signal transfer and prevents corrosion
- 100% aluminum foil coverage with 25% overlap with annealed stranded tin copper (ASTM B-33) drain wire prevents outside interference
- CM/CMG rated -4° to 167° F (-20° to 75°), UL2464 rated -4° to 176° F (-20°to 80° C) for adaptability
- Small 0.167" nominal O.D. makes it easy to hide or run under tight spaces
Your Price: $30.98
MSRP: $46.99
5 In Stock
We'll send you an email when 22/2 Shielded Mic/Line Cable with Drain Wire 100 ft. is back in stock or available for preorder.
Order in the next 6 hr 4 min to ship today. Details
