  • RESTOCKED PRV Audio 15W1600 15" High Power PA Woofer 8 Ohm
CLEARANCE RESTOCKED PRV Audio 15W1600 15" High Power PA Woofer 8 Ohm
PRV AudioPart # 88-294-2742
Model: 15W1600
Refurbished/Restocked products may be factory authorized B stock or C stock that have been returned by customers or retailers for a variety of reasons and have been reviewed, repaired, or repackaged by the manufacturer or our in house repair department. They may have slight scratches, dents, signs of use, or other forms of cosmetic damage that do not affect usability or performance. Packaging may be non-original. Some items may be missing non-essential parts.
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No-Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund.
View This Item New
Choose the PRV Audio 15W1600 15" woofer for use as a replacement speaker in high-end speaker cabinets. Its class leading power handling, subwoofer-like low frequency reproduction, and high sensitivity means more output for your driver dollar!
  • Extreme forced-air cooling system for hours of use without failure
  • 4" voice coil on a Kapton® former for 800W of power handling
  • 7.6 mm of Xmax and a low Fs for playing below 40 Hz with authority
  • Ribbed paper cone captures that "classic tone" of high-end speakers
  • High 97 dB sensitivity
CLEARANCE $144.00
MSRP: $209.98
Save $65.98 (31%)
2 In Stock
We'll send you an email when RESTOCKED PRV Audio 15W1600 15" High Power PA Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 3 hr 3 min to ship today. Details
PRV Audio's 15W1600 15" professional audio woofer is designed for high-end performance, in both PA and high SPL mobile audio systems. From the dual spider suspension mounted on a cast aluminum frame, 4" diameter voice coil with Kapton® former and an impressive 7.6 mm of Xmax, to the forced air ventilation system that keeps the motor cool even during massive power spikes, the 15W1600 was designed to compete against cost-no-object 15" woofers, and even subwoofers, well outside of its price point.
A non-pressed ribbed pulp cone offers a natural classic tone found in most high-end PA speaker cabinets, making the 15W1600 driver an ideal replacement woofer or subwoofer in both ported and sealed speakers. A special compound is incorporated into the the woven cotton surround to resist against wear for years of use. Spring-loaded speaker terminals make quick connection a breeze.
BrandPRV Audio
Model15W1600
Part Number88-294-2742
Weight27.25
