CLEARANCE RESTOCKED PRV Audio 12SW6000BP-2 12" Subwoofer Driver 2 Ohm
PRV AudioPart # 88-294-3238
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No-Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund.
View This Item NewPRV Audio’s unique 12SW6000BP-2 Brazilian Punch series 12” high efficiency 2 ohm subwoofer is built to deliver maximum impact and punch to open air designs, such as a stunt wall. This formidable driver features a huge 4” voice coil, stout cast aluminum frame, and massive double stacked motor. If you need head turning output with chest thumping bass response then the 12SW6000BP-2 is the driver for you.
- 92.5 dB efficiency with 3,000 watt RMS power handling for unbelievable output capability
- 10.75 mm Xmax allows ample displacement to deliver heart stopping low frequency impact
- Massive double stacked motor keeps precise control over the large 4” voice coil
CLEARANCE $292.00
1 In Stock
We'll send you an email when RESTOCKED PRV Audio 12SW6000BP-2 12" Subwoofer Driver 2 Ohm is back in stock or available for preorder.
