  • RESTOCKED Dayton Audio WF60PA 60W Class D Full Range 2.1 Plate Amplifier with Wi-Fi and Bluetooth
CLEARANCE RESTOCKED Dayton Audio WF60PA 60W Class D Full Range 2.1 Plate Amplifier with Wi-Fi and Bluetooth
Dayton Audio
Part #88-300-781
Dayton Audio
Part #88-300-781
Model: WF60PA
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
View It New
Dayton Audio's feature-packed WF60PA full-range Class D plate amplifier makes it easy to add high-quality Wi-Fi (Hi-Fly App Control) and Bluetooth 4.0 (with aptX®) wireless connectivity to your speakers. With 2 x 30 watts (4 ohm minimum) of power, it is perfect for creating a pair of active bookshelf or multimedia speakers.
  • Selectable optical, RCA, and 3.5 mm inputs for traditional wired connections
  • Convenient Wi-Fi App control and Bluetooth 4.0 connectivity
  • Full feature wireless remote for simple, convenient operation
  • Signal sensing standby mode automatically powers down amplifiers after 15 minutes of inactivity
  • Mono subwoofer output makes it easy to add a powered subwoofer
  • Control music player from remote (PLAY, PAUSE, PREVIOUS, and SKIP) in Bluetooth mode
  • Only 4.5" W x 6.25" H, perfect for creating small powered bookshelf or monitor speakers
CLEARANCE $93.00
MSRP: $165.00
Save $72.00 (44%)
Order in the next 0 hr 19 min to ship today. Details
3In Stock
Your Current Sound System Redefined
This Wi-Fi amplifier is easy to set-up, just connect this amp to any set of speakers for quick, affordable whole-house audio system.
MULTI-ROOM
Play synchronized audio in multiple rooms for seamless listening.
MULTI-CHANNEL
Play any song to any single device or group devices together.
MULTI-USER
Different users can control the audio source for different devices.
Your Music. Your Way. Take Control.
Let your audio listening experience soar with Hi-Fly™ multi-room Wi-Fi audio technology from Dayton Audio. With the Hi-Fly App, you can stream your favorite online music services, listen to music directly from your device, or play music stored on your home computer or the USB plugged directly into the back of the WF60PA. The Dayton Audio WF60PA Wi-Fi audio amplifier and all other Hi-Fly products work in harmony with the Hi-Fly App to provide the ultimate in affordable multi-room, multi-channel, and multi-user audio.
Easy Solution to Build a Powered Wi-Fi Speaker System
The WF60PA from Dayton Audio makes it possible to create a pair of custom active speakers with Bluetooth and App controlled Wi-Fi connectivity. This plate amp is ideal for the project builder or OEM, with endless applications. Use the WF60PA to build multimedia speakers, powered monitor speakers, or even retrofit existing speakers!
With multiple input options including optical, RCA, 3.5 mm, Bluetooth 4.0 with aptX ®, and Wi-Fi, the WF60PA is easy to integrate in any audio system. The convenient wireless remote allows full control of the amplifier's power, volume, and input (Bluetooth mode also allows you to control play, pause, previous and next track). In addition, a mono line level subwoofer out makes it easy to integrate a powered subwoofer into the system if needed.
To mount the WF60PA, a 4" x 5.5" hole is required for the amplifier. Installation of the IR receiver/LED module requires a 0.875" diameter, 0.125" deep recess for the plexiglass window with a 0.625" through hole. For speaker connections, a 30" lead is factory terminated with 0.205" disconnects for easy connection to driver or crossover terminals. Gold plated 5-way binding posts are provided for connecting the second speaker.
Super Simple Setup
Setting up the WF60PA amplifier is simple, start by downloading the free Dayton Audio Hi-Fly™ App from either the Play Store or App Store. Once the App is installed, open it on your mobile device or tablet and follow the step by step directions. If using a wired connection, the directions in the App are not required; just open the app and your device is ready for use.
Control the Airwaves at Home
The Dayton Audio Hi-Fly™ App turns your mobile device or tablet into a remote control for all Dayton Audio Hi-Fly™ enabled devices. Play music from your favorite streaming providers like Spotify, or from your home network or mobile device. With Hi-Fly you can send music to individual WF60PA amplifiers, or group your Hi-Fly enabled systems together for true multi-room audio. Plus, your music continues to play even if your phone is turned off or you need to take a call.
Specifications: • Output power: 2 x 30 watts RMS (Class D) into 4 ohms minimum • Signal to noise ratio: >95 dB • Frequency response: 45 to 20,000 Hz • Total Harmonic Distortion: 0.4% at 20 watts • Inputs: AUX 1: 2 x RCA, AUX 2: 3.5mm Stereo, S/PDIF Optical: Toslink • Outputs: 30" lead with 0.205" disconnects, Dual 5-way binding posts, RCA LFE Subwoofer Output • Bluetooth audio profiles: aptX, A2DP, AVRCP, HFP, and HSP • Bluetooth range: 33 ft. (10 m) • Wi-Fi: 2.4 GHz, Apple AirPlay® DLNA, Hi-Fly App compatible • Power requirements: 90/230 VAC, 50/60 Hz, 80 Watts • Stand-by power rating: 115V <0.5 Watts • Dimensions: 4.5" W x 6.25" H x 4" D • Mounting hole: 4" W x 5.75" H • Screw holes: 0.175".
Powered by LinkPlay Wi-Fi audio technology.Click here to learn more about custom integration of LinkPlay technology in your products.
ModelWF60PA
Part Number88-300-781
Weight2.55
