CLEARANCE RESTOCKED Dayton Audio RS150P-4A 6" Reference Paper Woofer 4 Ohm
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No-Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund.
View This Item NewDayton Audio Reference Series paper cone drivers combine class-leading low distortion performance with the use of a proprietary cone blend. Now with a flatter frequency response and smoother high frequency roll-off allowing for extended bandwidth and easier crossover integration.
- Now with improved frequency response for easier crossover integration
- Three-part paper composite diaphragm featuring paper, Kevlar, and glass fibers
- Low-distortion motor, 6-hole cast frame, rubber surround, and solid aluminum phase plug
CLEARANCE $31.00
MSRP: $55.99
1 In Stock
We'll send you an email when RESTOCKED Dayton Audio RS150P-4A 6" Reference Paper Woofer 4 Ohm is back in stock or available for preorder.
