  • Pyramid PS14KX 13.8V 12A DC Power Supply
CLEARANCE Pyramid PS14KX 13.8V 12A DC Power Supply
PyramidPart # 120-539
Model: PS14KX
This regulated power supply features binding posts for simple and secure hookup. It's perfect for powering 12 VDC devices that draw up to 12 amps.
  • Rugged & durable housing construction
  • Electronic overload with auto reset and short circuit protection
  • Normal and overload protection LED indicator
  • Hassle-free screw terminal connectors
  • Linear/regulated power supply design for constant voltage
  • Illuminated on/off switch for power on notification
CLEARANCE $100.57
MSRP: $106.99
Save $6.42 (6%)
We'll send you an email when Pyramid PS14KX 13.8V 12A DC Power Supply is back in stock or available for preorder.
This item is no longer available
The Pyramid bench power supply makes for a great addition to any hobbyist work desk or equipment testing station. It provides convenient and reliable AC-to-DC power performance needed by 12 V devices or projects that draw less than 12A. The built-in electronic overload and short-circuit protection, with auto reset, ensure safe operation and the illuminated power switch alerts you to power-on status. The heavy duty case holds up to bench type work and the universal hardwired screw-type terminals ensure hassle-free connection and are compatible with a wide range of components.
Specifications: • Output voltage: 13.8 V (fixed) • Output current: 12 amps (continuous), 14 amps (surge) • Ripple voltage: Less than 150mV RMS at rated output • Input voltage: 115 VAC, 60 Hz • Dimensions: 7.9" L x 7.2" W x 4.7" H.
BrandPyramid
ModelPS14KX
Part Number120-539
UPC068888701662
Weight9.25
DC Output Voltage13.8V
Input Voltage120 VAC
