  • Pyle PLCM7500 Backup Rear View Camera Parking / Reverse Assist System with 7" LCD Monitor
2 Questions, 2 Answers or
Pyle Audio
Part #267-7424
Pyle Audio
Part #267-7424
Model: PLCM7500
The Pyle PLCM7500 monitor and color backup camera displays “distance lines” clearly marking how far you are from visible obstacles even in low light situations.
  • Standard RCA video output/input connectors for easy hookup
  • Vivid 7" TFT color LCD 16:9 aspect ratio monitor
  • 420 lines of color resolution backup camera with distance scale lines for close parking situations
  • Marine grade waterproof and fog resistant construction backup camera
  • Built-in low light performance for night vision
  • Cameras mounting holes align with all car license plates
  • Camera and monitor automatically activate when placed in reverse gear
Your Price: $92.98
Quantity:Qty: 1-3 $92.98/ea
Quantity:Qty: 4+$85.71/ea
The Pyle PLCM7500 backup parking assist camera mounts above your vehicle's license plate. Pair it with the kit's 7" monitor display screen, for a quick and easy way to add safety when on the road. This camera adds low light capability, true color reproduction, all-weather performance -- and it's all housed in marine grade waterproof and fog resistant construction. The camera outputs a clear, vivid picture along with distance scale lines to help you drive safer and to get into those tight parking spots. System includes all the necessary cables and wiring for installation. Built-in low light performance for dark environments helps you steer when visibility is limited.
The 7" monitor automatically comes on when you put your vehicle in reverse gear. It switches off when driving forward. The screen has a wide 16:9 aspect ratio and has the ability to hookup two video sources. Drive safer and smarter with the Pyle PLCM7500 parking assist backup camera and monitor kit.
Monitor: • Size: 5.24" H x 7.6" W x 0.98" D • Screen: LCD color 7" • Video inputs: Two RCA jacks • Video system: PAL/NTSC • Aspect ratio: 16:9.
Camera: • Size: 10" L x 1.3" W x 1.26" H • Waterproof rating: IP67 • Low light performance: 0.2 LUX • lines of resolution: 420 • Total Pixels: 656 x 492 • Viewing angle: 170° • Power supply:12 VDC 200 mA • Video output: 1.0V PP-75 ohm.
BrandPyle Audio
ModelPLCM7500
Part Number267-7424
UPC068888733731
Weight2.15
