  • Pyle PDWR445TB 3.5" On Wall / Patio Commercial Speaker Black 8 Ohm / 70V
NEW Pyle PDWR445TB 3.5" On Wall / Patio Commercial Speaker Black 8 Ohm / 70V
Pyle Audio
Part #248-490
Pyle Audio
Part #248-490
Model: PDWR445TB
The Pyle PDWR445TB is a versatile indoor/outdoor wall-mounted speaker designed for high-quality audio performance in various environments, including patios, decks, and commercial spaces. Its marine-grade waterproof construction ensures durability and reliability, making it suitable for both indoor and outdoor installations.
  • IP54 rating for durability in outdoor environments
  • 2-way full-range stereo sound for balanced audio reproduction
  • Custom-tooled design for high power handling and deep bass response
  • Removable, rustproof aluminum speaker grills for added protection
  • Gold-plated speaker plug terminals for secure and corrosion-resistant connections
  • Adjustable mounting bracket for flexible wall installation
  • Rotary selector switch for easy selection between 70V line taps or 8-ohm operation
NEW $66.98
Quantity:Qty: 1-3 $66.98/ea
Quantity:Qty: 4+$60.28/ea
Order in the next 0 hr 2 min to ship today. Details
The PDWR445TB features a 3.5-inch long-throw woofer with a mica cone and rubber surround, delivering deep bass and clear midrange frequencies. Its 0.5-inch polymer dome tweeter ensures crisp high-frequency reproduction, resulting in a well-balanced sound profile. With a peak power rating of 40 watts and an RMS power of 20 watts, this speaker is capable of providing robust audio output suitable for various applications. The adjustable mounting bracket allows for flexible installation, enabling you to position the speaker for optimal sound dispersion. Additionally, the rotary selector switch facilitates easy selection between 70V line taps or 8-ohm operation, providing versatility for different audio system configurations. The speaker's marine-grade IP54 rating ensures protection against dust and water, making it ideal for outdoor use. Its heavy-duty engineered plastic composite cabinet and rustproof aluminum grills contribute to its durability and longevity, even in challenging environments.
Technical Specifications
  • Marine Grade IP54 Rating
  • 3.5” Long Throw Woofer
  • Magnet Size: 7.8 oz.
  • Cone Material: Mica + Rubber Surround
  • 0.5'' Polymer Dome Tweeter
  • Rated Peak Power: 40 Watt
  • Rated RMS Power: 20 Watt
  • Frequency Response: 114Hz-20kHz
  • Impedance: 8 Ohm
  • 70V Transformer Tapping: 20W/10W/5W/2.5W/8 Ohm
  • Product Dimensions (L x W x H): 5.91'' x 4.33” x 7.87''
BrandPyle Audio
ModelPDWR445TB
Part Number248-490
UPC842893149981
Weight3.5
