  • Precision Port PSP-4OFH 4" Outside Flare for Port Tube
Precision SoundPart # 268-376
Model: PSP-4OFH
The Precision Port™ "Create Your Own Port" system allows you to build your own custom length port to your needs using parts made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
  • Create custom 4" Precision Ports
  • Reduces port noise for clean bass output
  • Sturdy ABS construction made to tight tolerances
  • Proudly made in the USA!
Your Price: $6.13
MSRP: $8.99
Save $2.86 (32%)
We'll send you an email when Precision Port PSP-4OFH 4" Outside Flare for Port Tube is back in stock or available for preorder.
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products. Proudly made in the USA!
The PSP-4OFH 4" outside flare reduces the turbulence associated with other vents and port tubes by slowing down the vent air velocity, rendering port noise inaudible. The outside flare is built with four holes pre-drilled for mounting purposes.
The PSP-4OFH 4" outside flare is designed to work with the 4" connecting ring (PSP-4RG) when used with the 4" x 12" port tube (PSP-4TB). Finish off your port tube with the 4" inside flare (PSP-4IF) for even more port noise reduction. You can additionally connect inside and outside flares directly to one another using the connecting ring.
Dimensions: • Outside diameter: 7-1/4" • Cutout diameter: 6-1/4" • Overall length: 3" • Usable length (due to flare): 2-1/2".
BrandPrecision Sound
ModelPSP-4OFH
Part Number268-376
UPC848864000534
Weight0.27
