  • Precision Port PSP-4TB 4" Dia. x 12" Long Port Tube
Precision SoundPart # 268-382
Model: PSP-4TB
The Precision Port™ "Create Your Own Port" system allows you to build your own custom length port to your needs using parts made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
  • Create custom 4" ports
  • Sturdy ABS construction made to tight tolerances
  • Proudly made in the USA!
Your Price: $11.13
Save $4.86 (30%)
We'll send you an email when Precision Port PSP-4TB 4" Dia. x 12" Long Port Tube is back in stock or available for preorder.
Order in the next 4 hr 1 min to ship today. Details
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products. Proudly made in the USA!
The PSP-4TB 4" diameter x 12" long ABS port tube is used in conjunction with the 4" connecting ring (PSP-4RG) to connect to either the inside flare (PSP-4IF) or outside flare (PSP-4OFH) to create a custom length Precision Port.
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • Outside diameter: 4-1/8" • Inside diameter: 4" • Length: 12".
BrandPrecision Sound
ModelPSP-4TB
Part Number268-382
UPC848864000589
Weight0.5
