  • Polk Audio ES35 Signature Elite Slim Center Channel Speaker
NEW Polk Audio ES35 Signature Elite Slim Center Channel Speaker
Polk AudioPart # 243-641
Model: ES35 Black
The Signature Elite ES35 is a slim center-channel speaker designed to deliver clear, lifelike dialogue and cinematic sound without obstructing your TV. It features Hi-Res Audio certification and is compatible with Dolby Atmos and DTS:X, making it ideal for premium home theater systems.
  • Low-profile design fits beneath most TVs or wall-mounted as L/C/R channels
  • Seven-driver acoustic array (six 3″ woofers + 1″ tweeter) for precise dialogue and immersive soundstage
  • Hi-Res Audio Certified Terylene dome tweeter supports frequencies beyond 40 kHz
  • Dual Polk Power Ports enhance bass output without increasing enclosure size
  • Anti-diffraction magnetic grille reduces sonic interference for clearer sound
  • Slim, wall-mountable design delivers flexibility in placement
  • Compatible with Dolby Atmos and DTS:X systems for immersive surround performance
NEW $359.00
MSRP: $399.00
Save $40.00 (10%)
We'll send you an email when Polk Audio ES35 Signature Elite Slim Center Channel Speaker is back in stock or available for preorder.
Powerful & Immersive Hi-Res Audio for Movies, TV, Music & Games
The Signature Elite ES35 high-performance, low-profile center channel speaker brings movies, games, and multi-channel music to life with crystal-clear dialogue and powerful cinematic sound—all without blocking your TV. Hi-Res Certified and compatible with Dolby Atmos and DTS:X, the ES35 delivers exceptional Polk sound quality at an accessible price.
Balanced Cinematic Sound
Low Profile & Wall Mountable for Flexible L/C/R Placement
The ES35’s slim center channel design fits neatly beneath your TV, delivering powerful sound without blocking your screen or remote sensor. Its versatile, wall-mountable build also allows it to serve as left, right, or surround channels, creating immersive home theater audio without taking up floor or shelf space.
Make Your Entire Home Theater the Sweet Spot
Enjoy a seamless, lifelike soundstage from any seat in the room. The Signature Elite ES35’s Dynamically Balanced seven-driver array with phase-optimized cascaded crossovers delivers clear, focused dialogue that integrates perfectly with other Signature Elite speakers.
Hear More Detail in Music and Movies You Love
The ES35’s Hi-Res Audio Certified Terylene dome tweeter delivers crystal-clear highs extending beyond 40kHz, making it perfect for enjoying the detailed sound of ultra-HD movies, multi-channel concert recordings, and spatial audio formats like Apple Music, Dolby Atmos, and DTS:X.
Effortless Bass
In movies, the center channel carries up to 75% of the audio, including voices, music, and sound effects, but most center speakers are designed mainly for dialogue. The ES35’s dual Polk Power Ports produce deeper, more powerful bass so you can hear and feel every detail exactly as the director intended.
Built for Pure Sound
Quiet Cabinet
A strong, rigid, and acoustically inert enclosure made from critically damped Medite MDF with laser-optimized bracing minimizes internal standing waves and resonance, reducing coloration and distortion for cleaner sound.
Low-Interference Grille
The ES35’s anti-diffraction magnetic grille reduces sonic interference and can be easily removed for a bold, refined appearance.
Direct Connection
Gold-plated five-way binding posts provide a direct, efficient, and lossless connection for optimal signal transfer.
Hi-Res Audio Certified Polk speakers deliver an immersive listening experience, capturing every nuance and detail of high-quality recordings while offering exceptional audio fidelity.
Polk’s patented Power Port design increases surface area and smooths airflow, delivering higher output with lower distortion compared to traditional ported speakers.
Proudly engineered and designed in Baltimore, Maryland, Polk speakers are built to meet the highest standards of quality, performance, and reliability, delivering a premium audio experience that defines American Hi-Fi.
The Terylene dome tweeter pairs with a powerful low-resonance ceramic motor structure to deliver exceptionally detailed sound beyond 40 kHz, enhancing the clarity and depth of high-resolution music.
Polk’s exclusive lightweight Dynamic Balance® polypropylene cones provide exceptional midrange clarity, powerful bass, and impressive efficiency.
  • Tweeter: 1"/2.54cm Terylene dome tweeter
  • Mid-Bass: (6) 3"/7.62cm low distortion mica-fortified polypropylene drivers
  • Crossover Frequency: 2.7kHz
  • Recommended Amplification (wpc): 20–150W
  • Impedance: Compatible with 4- and 8-ohm outputs
  • Overall Frequency Response: 68Hz–40kHz
  • Sensitivity (2.83V @ 1m): 89dB
  • Inputs: Single gold-plated 5-way binding posts
  • Dimensions: (W)620mm x (H)104mm x (D)155mm ( (W)24.4" x (H)4.1" x (D)6.1" )
  • Weight: 14 lbs. / 6.4 kg
BrandPolk Audio
ModelES35 Black
Part Number243-641
UPC747192134235
Weight16.8
ColorBlack
Configuration2-way
Input Rating150
Mounting StyleWall Mount
Woofer Diameter3"
