  • Polk Audio Atrium Sub 100 10" Outdoor Subwoofer
Polk AudioPart # 243-620
Model: Atrium Sub 100
The Polk Atrium Sub100 is designed to seamlessly blend with the great outdoors, offering incredible versatility. You have the flexibility to plant it in your landscaping, or install it wherever you desire to enjoy exceptional outdoor sound. With its weather-resistant construction, this subwoofer is built to withstand the elements, ensuring reliable performance in various outdoor settings.
  • 10"long-throw Dynamic Balance® driver for deep, clean bass
  • Weatherproof sealed enclosure with IPX66 rating for all-weather durability
  • Dual 2" voice coils for enhanced low-frequency response
  • Paintable enclosure to blend with outdoor décor
  • Supports up to 200 watts of power for robust performance
  • Flexible installation options, including use as a plant stand or pedestal table
Dayton Audio IOSUB 10" IP66 Indoor/Outdoor Subwoofer 150W Black
Price: $265.98Part # 310-026
See all items in Outdoor Speakers
Your Price: $549.00
1 In Stock
We'll send you an email when Polk Audio Atrium Sub 100 10" Outdoor Subwoofer is back in stock or available for preorder.
Order in the next 4 hr 41 min to ship today. Details
Polk Audio Atrium SUB100 Outdoor Subwoofer
The Subwoofer for All Seasons
Experience the power of the heavy-duty all-weather outdoor subwoofer, featuring a 10" downward-firing long-throw dual voice coil driver. This impressive subwoofer is designed to deliver deep bass that enhances any outdoor space. Regardless of the weather conditions, you can count on the subwoofer to produce powerful and impactful bass, adding a new dimension to your outdoor audio experience.
Great Outdoor Sound
Weatherproof
Our subwoofer is housed in a moulded and sealed acoustically ideal resin enclosure, ensuring exceptional audio performance. It is also marine-certified with an IPX66 rating, guaranteeing years of weather-proof outdoor performance. No matter the conditions, you can trust that this subwoofer will stand strong, delivering reliable and high-quality sound in any outdoor environment. Its durability and weather-resistant design make it the perfect companion for outdoor living spaces, ensuring you can enjoy deep bass and immersive audio for many years to come.
Capacitive Coupling Technology
With its dual 2-inch voice coil design, this subwoofer effortlessly reproduces bass from both stereo channels, resulting in more power in the lower frequencies, all thanks to Capacitive Coupling Technology. The result is big outdoor bass, making a significant impact in any outdoor setting. Enjoy powerful and immersive sound that enhances your outdoor entertainment, whether it's hosting gatherings, relaxing on the patio, or enjoying outdoor activities. This subwoofer is designed to deliver deep and impactful bass, ensuring that your outdoor audio experience is truly exceptional.
Designed to Blend In
The Sub100's enclosure offers the flexibility to be painted to match your landscape design, ensuring it seamlessly blends in with your outdoor decor. The color-impregnated resin construction ensures that the color will never fade, maintaining its vibrant appearance for years to come. The Sub100 naturally complements your outdoor seating, effortlessly integrating into the environment. Its versatile design even allows you to use it as a plant stand or pedestal table, adding functionality to its aesthetic appeal. With the Sub100, you can enjoy outstanding outdoor audio performance without compromising on style, creating a harmonious and beautiful outdoor space for relaxation and entertainment.
  • Subwoofer Array Driver Enclosure Type: Acoustic Suspension with Color-Impregnated Resin Shell
  • Subwoofer Array Driver Complement: (1) 10" (25.4 cm) d (Round) Long-throw Dynamic Balance composite cone driver with dual voice coils and butyl rubber surround - Subwoofer - Voice Coil 2" (5.08 cm) d
  • Height: 11" (27.94 cm)
  • Width: 16.9" (42.93 cm)
  • Depth: 16.9" (42.93 cm)
  • Weight: 16.75 lbs (7.6 kg)
  • Nominal Impedance: 8 ohms
  • Sensitivity (1 watt @ 1 meter): 88 dB
  • Lower and Upper -3dB Limits: 50 Hz to 110 Hz
  • Recommended Amplifier Power Per Channel: 10 watts to 200 watts
  • Peak Power Handling: 200 watts
  • Midrange/Woofer Crossover Frequency: 150 Hz
  • Power Handling (per channel): 10 watts to 200 watts
BrandPolk Audio
ModelAtrium Sub 100
Part Number243-620
UPC747192129293
Weight21.65
ConfigurationSubwoofer
Mounting StyleLandscape
Woofer Diameter10"
Special FeaturesIndoor / Outdoor-Water Resistant
