  • Pig Hog Tour Grade Instrument Cable Right Angle 18.5 ft.
CLEARANCE Pig Hog Tour Grade Instrument Cable Right Angle 18.5 ft.
Pig HogPart # 256-012
Model: PH186R
Pig Hog instrument cables are built to handle the demands of professional musicians and audio enthusiasts. Designed with proprietary conductor technology, robust shielding, and an extra-thick yet supple jacket, these cables resist tangling, prevent interference, and perform reliably for each and every gig.
  • Designed by musicians, for musicians
  • Built to stand up to the most punishing tour conditions
  • 8mm PVC jacket covering is tough but resistant to tangling or kinking
  • Proprietary conductor tech provides crystal clear sound
  • Hand tested before shipment by Pig Hog pros
  • Connectors protected by heat shrink
  • Limited Lifetime Warranty
CLEARANCE $29.95
MSRP: $54.95
Save $25.00 (45%)
10 In Stock
We'll send you an email when Pig Hog Tour Grade Instrument Cable Right Angle 18.5 ft. is back in stock or available for preorder.
Pig Hog Tour Grade Instrument Cables
Fat Cables. Fat Sound.
Designed by musicians and for musicians, Pig Hog cables are engineered to handle the harshest touring conditions while offering exceptional audio performance at an unbeatable value. Tour grade instrument cables feature an extra-thick yet flexible 8mm PVC jacket that resists kinking and tangling, ensuring durability and ease of use in any setup.
Utilizing proprietary conductor technology and robust shielding, these cables deliver crystal-clear sound with no noise or interference. Every Pig Hog cable is hand-tested before leaving the factory and comes with a limited lifetime warranty, guaranteeing reliability and making them a trusted part of your rig for years to come.
How to Wrap a Cable Correctly
Extend the life of your cables by wrapping them up right! Forget the elbow wrap; the over-under method will help keep your cables from forming kinks, creating bends in the copper, makes the cable easier to store, and extends the natural lifespan of the cable by reducing general wear and tear!
Explore the Hog Catalog
Don't see the Pig Hog cable you were looking for? Reach out and let us know!  We'll hook you up with whichever cable you're looking for; no minimums, no extra fees, no problems.
BrandPig Hog
ModelPH186R
Part Number256-012
UPC672485343295
Weight0.2
Cable Length18.5feet
Jacket ColorBlack
