  • Peerless by Tymphany TC5FB00-08 1-1/2" Paper Cone Full-Range Driver 8 Ohm
Peerless by TymphanyPart # 264-1620
Model: TC5FB00-08
The TC5FB00-08 is a 1-1/2" 8 ohm full-range driver, with ferrite magnet, paper cone and PU surround, and steel basket. This driver is designed to be a cost-effective high performance full range driver.
Your Price: $11.29
MSRP: $14.99
Save $3.70 (25%)
200 In Stock
We'll send you an email when Peerless by Tymphany TC5FB00-08 1-1/2" Paper Cone Full-Range Driver 8 Ohm is back in stock or available for preorder.
Order in the next 9 hr 0 min to ship today. Details
The TC5FB00-08 is a 1-1/2" 8 ohm full-range driver, with ferrite magnet, paper cone and PU surround, and steel basket. This driver is designed to be a cost-effective high performance full range driver. The product was designed with portable and other compact applications in mind.
BrandPeerless by Tymphany
ModelTC5FB00-08
Part Number264-1620
UPC848864045788
Weight0.15
Nominal Diameter1-1/2"
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Sensitivity79.36dB 2.83V/1m
Voice Coil Diameter0.64"
Resonant Frequency (Fs)261.01Hz
DC Resistance (Re)6.74Ω
Voice Coil Inductance (Le)0.07mH
Mechanical Q (Qms)3.84
Electromagnetic Q (Qes)2.81
Total Q (Qts)1.62
Compliance Equivalent Volume (Vas)0.002ft³
Mechanical Compliance of Suspension (Cms)775.9mm/N
BL Product (BL)1.38T·m
Maximum Linear Excursion (Xmax)0.6mm
Surface Area of Cone (Sd)7.6cm²
Cone MaterialPaper
Surround MaterialPolyurethane
Overall Outside Diameter1.59"
Baffle Cutout Diameter1.44"
Depth0.85"
Sealed Volume0.01ft³
Sealed F3202.8Hz
