  • Wavecor FR040WA02 1-1/2" Neodymium Aluminum Cone Full-Range 8 Ohm
WavecorPart # 298-2002
Model: FR040WA02
The Wavecor FR040WA02 is a 1-1/2" aluminum cone fullrange that is designed for compact multimedia installations. The FR040WA02 is a very good choices for any project requiring fullrange audio in a compact space.
  • True full-range design with on-axis output to beyond 20,000 Hz
  • Dual neodymium magnet structure for high efficiency and almost ideal magnetically shielding
  • Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
  • Vented polymer chassis for lower air flow speed reducing audible distortion
  • Vented voice coil former for reduced distortion and compression
  • Low-loss suspension (high Qm) for better reproduction of details and dynamics
  • Conex spider for better durability under extreme conditions
Your Price: $25.90
MSRP: $37.00
Save $11.10 (30%)
34 In Stock
We'll send you an email when Wavecor FR040WA02 1-1/2" Neodymium Aluminum Cone Full-Range 8 Ohm is back in stock or available for preorder.
The dual neodymium motor system with a 16 mm voice coil diameter offers better control, power handling, and efficiency. The optimized aluminum cone ensures an extremely wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelFR040WA02
Part Number298-2002
UPC848864054025
Weight0.1
Nominal Diameter1-1/2"
Bolt Circle Diameter1.81
Power Handling (RMS)15 Watts
Power Handling (MAX)35 Watts
Frequency Response200 to 20,000Hz
Sensitivity81dB 2.83V/1m
Voice Coil Diameter0.63"
Resonant Frequency (Fs)239Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.08mH
Mechanical Q (Qms)9.4
Electromagnetic Q (Qes)1.42
Total Q (Qts)1.23
Compliance Equivalent Volume (Vas)0.002ft³
Mechanical Compliance of Suspension (Cms)0.74mm/N
BL Product (BL)2T·m
Maximum Linear Excursion (Xmax)0.5mm
Surface Area of Cone (Sd)7.8cm²
Cone MaterialAluminum
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter1.57"
Baffle Cutout Diameter1.46"
Depth0.98"
Sealed Volume0.004ft³
Sealed F3214.3Hz
