  • Peavey PVs 12 SUB 12" 1,000 Watt Powered Subwoofer
CLEARANCE Peavey PVs 12 SUB 12" 1,000 Watt Powered Subwoofer
PeaveyPart # 248-9930
Model: PVs 12 SUB
Introducing the Peavey PVs 12 SUB 12" 1,000 Watt Powered Subwoofer, a powerhouse of low-end might designed to elevate your audio experience. Whether it’s for live events, studio playback, or enhancing your home entertainment system, this subwoofer delivers unparalleled depth and clarity to your sound.
  • Deep, Powerful Bass: Delivers up to 1,000 watts of peak power, providing rich, impactful low-end performance.
  • High-Efficiency 12-Inch Woofer: Designed for maximum bass response and reliability, ensuring detailed low frequency reproduction.
  • Compact and Durable Design: Easily fits into any setup with its space-saving footprint, while the rugged construction withstands demanding use.
  • Simple Integration: Features balanced XLR inputs and outputs, making it easy to connect with your existing audio equipment.
  • Phase Reversal Switch: Offers flexibility in aligning the subwoofer’s output with your main speakers for optimal sound quality.
Gemini ZRX-S18BT 18" Powered PA Subwoofer w/ Bluetooth
Price: $599.95Part # 235-149
See all items in PA Speaker Systems
We'll send you an email when Peavey PVs 12 SUB 12" 1,000 Watt Powered Subwoofer is back in stock or available for preorder.
With a peak power of 1,000 watts, the PVs 12 SUB brings the foundational rumble and punch that every sound system craves. Its 12-inch high-efficiency woofer moves air with precision and power, ensuring every beat and bass line is felt just as intensely as it is heard.
Peavey's commitment to quality is evident in the design of the PVs 12 SUB. The meticulously crafted woofer is optimized for low frequency excellence, guaranteeing a bass response that is both deep and clean, even at the highest output levels.
This subwoofer’s compact design makes it an ideal choice for venues and setups where space is at a premium. Despite its small footprint, the PVs 12 SUB is built to Peavey's rigorous standards for durability, ready to withstand the rigors of the road and constant use.
Connecting the PVs 12 SUB to your existing sound system is straightforward, thanks to its balanced XLR inputs and outputs. This ensures a clean, noise-free connection whether you’re linking directly to a mixer, active speakers, or additional subwoofers.
Fine-tune your audio setup with the subwoofer’s phase reversal switch, a feature that allows you to align the PVs 12 SUB’s output with your main speakers. This flexibility ensures that your system’s bass is perfectly synced, delivering a cohesive and immersive listening experience.
  • Frequency Response: 53 Hz – 180 Hz (Crossover Control Full CW), 53 Hz – 90 Hz (Crossover Control full CCW)
  • Low Frequency range (-10 dB, half space): 48 Hz
  • Power Amp Rating: 1,000 watts peak available power
  • Sine wave Power: 500 watts into 4 ohms (Output duration is limiter controlled)
  • Electronic Input Impedance (Nominal): Line In: 20 k ohms balanced (XLR or 1/4”), 10 k ohms unbalanced 1/4”
  • Maximum Sound Pressure Level (1 meter in half space): 122 dB SPL continuous, 125 dB SPL peak
  • Transducer Complement: 12” premium heavy-duty woofer, 2.5” voice coil, 50 oz. magnet.
  • Box Tuning Frequency: 50 Hz
  • Input Connections: One combo female XLR/ 1/4” phone jack providing balanced or unbalanced operation
  • Output Connections: Two High Pass Outputs, One Full Range Thru
  • Level Controls: Provides Off to + 20 dB gain adjustment
  • Crossover Frequency Adjust: Adjusts electrical crossover frequency from 90 Hz to 180 Hz, in 15 discrete steps
  • Polarity Switch: Provides either Normal (0 degrees) or Reversed (180 degrees) sub woofer polarity
  • Ground Lift Switch for input
  • Electronic Crossover: Linkwitz-Riley crossover variable from 90 Hz to 180 Hz.
  • Low Pass slope: 24 dB/octave
  • High Pass Output slope: 24 dB/octave
  • Infrasonic Filter Slope: 36 dB/octave
  • THD and IM: Typically less than 0.1 %
  • Power Requirements: Nominal 160 Watts, 100-120 VAC 50-60 Hz
  • Enclosure Materials & Finish: Black acrylic painted enclosure with 15 mm MDF, with a full-length, black powder coated perforated steel grille.
  • Dimensions (H x W x D)L 21.82 in. x 14.38 in. x 20.13 in. (554 mm x 365 mm x 511 mm)
  • Net Weight: 57 Lbs.(25.9 kg)
  • Mounting Provisions: Two 1 3/8” pole mounts with M20 threaded pole for stand mounting a suitable speaker on top of the Sub, and four large rubber feet on bottom and on the side for floor use. Threaded pole is supplied with the unit
BrandPeavey
ModelPVs 12 SUB
Part Number248-9930
Weight73.35
ConfigurationSubwoofer
Speaker TypeActive / Powered
Woofer Size12"
