  • Gemini ZRX-S18BT 18" Powered PA Subwoofer w/ Bluetooth
NEW Gemini ZRX-S18BT 18" Powered PA Subwoofer w/ Bluetooth
GeminiPart # 235-149
Model: ZRX-S18BT
The Gemini ZRX-S18BT is a professional-grade 18" powered subwoofer designed to deliver deep, impactful bass for DJs, live performers, and event venues. With 600W RMS (2400W peak) Class D amplification and Bluetooth streaming with TWS stereo pairing, it offers both power and flexibility in a rugged, portable design.
  • 600W RMS / 2400W peak Class D amplifier delivers deep, distortion-free bass
  • Bluetooth 5.0 with TWS pairing for a wireless stereo setup
  • 18" high-excursion driver with 3" voice coil delivers a powerful low-frequency response
  • Phase switch and variable low-pass filter (80–200Hz) for precise tuning
  • Durable MDF cabinet with ergonomic metal handles for easy transport
  • Built-in 35mm pole mount allows for full-range speaker integration​
NEW $599.95
We'll send you an email when Gemini ZRX-S18BT 18" Powered PA Subwoofer w/ Bluetooth is back in stock or available for preorder.
2400-Watt Peak Power
High-efficiency 2400-Watt Class D amplifier paired with an 18” high-excursion driver featuring a 3” high-temperature voice coil.
Bluetooth Connectivity
Stream music wirelessly from any Bluetooth-enabled device within a 32 foot range.
Advance Technology
Digital signal limiter, LED indicator, high pass filter, and phase flip switch provide advanced sound control and protect against damage.
True Wireless Stereo
TWS Linking enables wireless pairing with another ZRX-S18BT to create a True Wireless Stereo pair.
Wireless Bluetooth Streaming for Instant Playback
Our Bluetooth technology provides a smooth, hassle-free connection, stable interference-free performance, and a 32-foot range for convenience.
Enjoy true wireless stereo with two subwoofers that link effortlessly for expanded sound and broader coverage. Add more subwoofers to extend the range and create a fully immersive audio environment.
State-of-the-Art DSP
Experience audio like never before with powerful sound, precision-crafted drivers, and advanced signal processing. Unlock the full potential of your music and elevate your listening experience.
Multiple Connections
The ZRX-S18BT offers multiple XLR balanced inputs and outputs, giving you outstanding flexibility to tailor your sound system to your exact requirements.
Easy Mobility
Built for effortless transport and easy handling, it features strong support and ergonomic grips—ideal for any party or event.
Massive Power
This ultra-compact subwoofer packs a punch with a 2400-Watt Class D amplifier and 18" large transducer, producing up to 130 decibels of room-filling, deep-shaking bass.
Custom Engineered, Precise Sound
Our Class-D amplifier technology provides powerful audio and top-tier performance in a compact, energy-efficient design by eliminating bulky components. Enjoy strong sound in a lightweight, sustainable package.
  • Active/Passive: Active: Say goodbye to external amps! The Gemini ZRX-S18BT Professional Subwoofer is an "Active" DJ's dream, with its built-in amplifier. Plug it in, and let this powerful subwoofer pump out some ground-shaking beats for your stage or event!
  • Class: D): This electrifying subwoofer sports a Class D amplifier, providing that deep bass and crystal-clear sound every DJ craves. Lightweight and efficient, this amp will give you a powerful performance without breaking a sweat!
  • Woofer Size: 18” Driver with 3” High Temperature Voice Coil: The Gemini ZRX-S18BT boasts a massive 18-inch driver with a 3-inch high-temperature voice coil, delivering deep, resonating bass that will leave your audience in awe. Bring your tunes to life with this big, bad subwoofer!
  • Woofer Power: 2400 Watts Peak: With a whopping 2400 Watts Peak power, this active subwoofer is ready to rumble! Perfect for DJs, stage performances, or pro audio setups, the ZRX-S18BT will make your music come alive with earth-shaking bass.
  • Frequency Response: 35Hz-150kHz: This versatile subwoofer covers a wide frequency range of 35Hz-150kHz, ensuring you'll have tight, punchy bass to complement your music. The ZRX-S18BT will make your tunes sound better than ever!
  • Impedance: 8 Ω: With an impedance of 8 ohms, this powerful subwoofer is compatible with a wide range of audio equipment. Connect it to your DJ or pro audio setup for a seamless and electrifying performance.
  • Max SPL @ 1M: 130 dB: Unleash the power of the Gemini ZRX-S18BT, with an impressive max SPL of 130 dB at 1 meter. This subwoofer is ready to make some noise, leaving your audience in awe of the deep, rumbling bass!
  • Bluetooth: Bluetooth Streaming with TWS Link: Stream your favorite tunes wirelessly with Bluetooth connectivity! The ZRX-S18BT also features TWS Link, allowing you to pair two subwoofers for that earth-shattering stereo sound experience.
  • Inputs/Outputs: Stereo XLR balanced inputs: Connectivity is a breeze with the Gemini ZRX-S18BT's Stereo XLR balanced inputs and full-range or hi-pass outputs. Easily integrate this subwoofer into your pro audio setup for a mind-blowing bass experience.
  • Enclosure Material: MDF Board: Built to withstand the rigors of the stage, the ZRX-S18BT's enclosure is made of MDF board. This sturdy material ensures your subwoofer stays protected, allowing you to focus on rocking the party!
  • Mounting Options: Pole Mount Hardware: Flexibility is key! The ZRX-S18BT includes pole mount hardware, making it easy to set up your subwoofer and speakers for a perfectly balanced audio experience.
  • Voltage: 25.0115 ~ 220V +/- 15%, 50/60 Hz: The Gemini ZRX-S18BT is adaptable and ready for action, supporting a wide voltage range of 25.0115 ~ 220V +/- 15%, 50/60 Hz. No matter where your music takes you, this subwoofer is ready to rock!
  • Dimensions: (H,W,L) 25.08" x 20.47" x 23.62" inches: This mighty subwoofer has a compact size of 25.08" x 20.47" x 23.62" inches and weighs 80.46 lbs, making it a portable and powerful addition to your DJ or pro audio setup. Easy to transport and set up, the Gemini ZRX-S18BT will help you create a spectacular audio experience at any event, big or small!
  • Weight: 80.46 lbs.
BrandGemini
ModelZRX-S18BT
Part Number235-149
UPC747705008299
Weight80.46
ConfigurationSubwoofer
Speaker TypeSubwoofer
Woofer Size18"
