  • Peavey AQ15 1,000W 15" Powered Speaker
PeaveyPart # 248-9928
Model: AQ15
1 Question, 1 Answer or
The Peavey AQ15 1,000W 15" Powered Speaker is a testament to Peavey's legacy of innovative audio solutions. Designed to meet the exacting standards of professional musicians, DJs, and speakers, the AQ15 combines high power with precision sound reproduction in a rugged, road-ready package.
  • Exceptional Power and Clarity: 1,000 watts of dynamic power ensures your sound cuts through in any environment.
  • Premium 15-Inch Woofer: Delivers deep, impactful bass and crystal-clear mids for a well-rounded sound profile.
  • Versatile Connectivity: Equipped with XLR, 1/4-inch, and RCA inputs, catering to a wide range of audio sources.
  • Durable Construction: Built to last with a rugged enclosure, ensuring it stands up to the rigors of the road.
  • Easy-to-Use Interface: Features onboard EQ controls for fine-tuning your sound, plus a convenient LCD display for quick adjustments.
Your Price: $499.99
MSRP: $699.99
Save $200.00 (29%)
We'll send you an email when Peavey AQ15 1,000W 15" Powered Speaker is back in stock or available for preorder.
Estimated back in stock 11/28/2025
At the heart of the AQ15's performance is its impressive 1,000 watts of power, capable of delivering sound that fills any room or venue with ease. The premium 15-inch woofer ensures that every note and word is articulated with clarity and richness, from the deepest bass to the clearest highs.
Adaptability is key in the world of professional audio, and the AQ15 excels with its range of input options. Whether you're connecting a mixer, a microphone, or a music player, the speaker's XLR, 1/4-inch, and RCA inputs make it easy to integrate into your existing setup.
The AQ15 is encased in a rugged enclosure, designed to protect its components from the bumps and scrapes of travel and use. This durability ensures that the speaker not only sounds great today but will continue to do so for years to come.
With onboard EQ controls and an intuitive LCD display, the AQ15 gives you the power to shape your sound to perfection. Adjust the bass, mid, and treble to suit the acoustics of your space and the nature of your audio, ensuring optimal performance in any setting.
Choosing the AQ15 means investing in Peavey's renowned quality and customer support. Whether you're a seasoned pro or just starting out, the AQ15 powered speaker offers a combination of performance, durability, and ease of use that's hard to beat.
  • Frequency Response: 62 Hz to 19 kHz, +/- 6 dB
  • Maximum Sound Pressure: 126 dB SPL
  • Dispersion: Nominal: 110 degrees horizontal X 80 degrees vertical
  • Heavy-duty 15” woofer with 2.38” voice coil & 54 oz. magnet
  • DX™14 1.4” titanium diaphragm dynamic compression driver
  • Box Tuning: 53 Hz
  • Input Connections: One combo female XLR / 1/4” phone jack providing balanced line-level operation from the 1 / 4” jack section, and the XLR section
  • Bluetooth® input via wireless link, with pairing options
  • Output Connections: One male XLR jack. The Thru/Mix jack is intended for the use of linking multiple AQ™15‘s in a line or to provide a feed to a powered subwoofer, or other electronics that needs to receive a full range version of the input
    signal
  • Overall Dimensions: 28.3”H x 16.75”W x 15.00”D (719 mm x 426 mm x 381 mm)
  • Weight: 44 lbs. (20.0 kg)
  • 1000 watts peak dynamic power
  • Power Consumption: 200 Watts, 120 VAC 60 Hz
BrandPeavey
ModelAQ15
Part Number248-9928
UPC014367672138
Weight45.15
Speaker TypeActive / Powered
