  • PRV Audio WGP14-25 Gold-S 1" 45 x 45 Waveguide 1-3/8"-18 TPI
PRV AudioPart # 294-3024
Model: WGP14-25 Gold-S
Give your high efficiency systems a bit of flare with PRV Audio's WGP14-25 gold finished exponential horn. Requiring just under 4" of mounting depth, this horn makes it easy to install a high output tweeter with minimal mounting depth. The 1" throat and 45° x 45° dispersion makes this perfect for applications where a tight coverage pattern is needed.
  • Under 4" of mounting depth for installation in tight spaces
  • 1" throat with standard 1-3/8"-18 TPI mount
  • Non-resonant reinforced plastic construction
  • Minimum recommended frequency of 600 Hz
Your Price: $14.91
Save $3.73 (20%)
We'll send you an email when PRV Audio WGP14-25 Gold-S 1" 45 x 45 Waveguide 1-3/8"-18 TPI is back in stock or available for preorder.
Order in the next 5 hr 48 min to ship today. Details
Add a little color to your sound, in a good way, with PRV Audio's WGP14-25 gold finished exponential horn. At under 4" of depth this horn makes installation easy in tight spaces. A standard 1-3/8"-18 TPI mount is compatible with most 1" compression drivers. The WGP14-25 Gold-S is constructed from non-resonant ABS plastic making it perfect for outdoor or automotive use. Acoustic loading is maintained down to 600 Hz.
Specifications:• Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 45° H x 45° V • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 6.09" H x 6.09" W x 4.33" D • Cabinet cutout: 5.51" dia.
BrandPRV Audio
ModelWGP14-25 Gold-S
Part Number294-3024
UPC602938021999
Weight0.2
ConstructionABS
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
