  • PRV Audio WGP10-25 SLIM 1" Waveguide
NEW PRV Audio WGP10-25 SLIM 1" Waveguide
PRV AudioPart # 294-2843
Model: WGP10-25 SLIM
The WGP10-25 SLIM by PRV Audio is a shallow 1-inch exit screw-on waveguide designed to pair with compatible compression drivers. It offers strong acoustic loading down to 1400 Hz while being suitable for tight mounting spaces. Built from non-resonant ABS plastic with a black finish it’s ideal for outdoor or automotive use.
  • Slim mounting depth of 1.75″ with compact 4.15″ × 4.15″ faceplate fits tight installations
  • 1-3/8″-18 TPI screw-on mount compatible with PRV 1-inch exit compression drivers
  • 90° × 90° dispersion pattern good for short-throw applications
  • Non-resonant reinforced ABS plastic construction resists outdoor or automotive stress
  • Accepts baffle cut-out diameters between 3.50″ and 3.75″ for easy front-mounting of selected drivers
NEW $14.91
MSRP: $18.64
Save $3.73 (20%)
We'll send you an email when PRV Audio WGP10-25 SLIM 1" Waveguide is back in stock or available for preorder.
Order in the next 4 hr 1 min to ship today. Details
The screw-on shallow waveguide WGP10-25 SLIM from PRV Audio is an exponential horn designed for installations where space is limited. With a depth of just 1.75″, it fits easily into tight areas. It uses a standard 1-3/8″-18 TPI screw-on mount, making it compatible with any PRV 1″ exit screw-on compression driver. Built from non-resonant ABS plastic, it is durable and well-suited for both outdoor and automotive applications, while maintaining acoustic loading down to 1400 Hz. As a slim version of the popular WG11-25 horn, it features a faceplate that is 3/8″ smaller overall, making it both shallower and more compact.
The WGP10-25 SLIM waveguide has a mounting depth of just 1.75″ and a compact 4.15″ x 4.15″ faceplate, making it easy to fit a compression driver between speakers. When paired with any PRV 1″ exit driver, it delivers powerful performance in tight spaces. The baffle cutout range of 3.50″ to 3.75″ allows for straightforward front mounting of drivers such as the D250Ti-S or DT175Ph-S. Its 90° x 90° dispersion pattern makes it a great choice for short-throw applications, while the reinforced, non-resonant plastic construction and unique dispersion design help reduce reflections for more consistent sound. A minimum recommended crossover frequency of 1,400 Hz is suggested, and the horn includes four screws for mounting.
  • Throat Diameter: 1” (25.4mm)
  • Mounting Type: Screw-on
  • Thread dimensions 1-3/8″
  • Nominal Coverage
    -Horizontal 75°
    -Vertical 75°
  • Flare type Exponential
  • Material Plastic (ABS)
  • Finish / Coating Black
  • Dimensions
    -Height 4.15” (105.5mm)
    -Width 4.15” (105.5mm)
    -Depth 2.07” (52.5mm)
    -Mount Depth 1.75” (44.5mm)
  • Baffle Cutout Diameter 3.75″ (95.5mm)
  • Net weight 0.15lb (0.07kg)
BrandPRV Audio
ModelWGP10-25 SLIM
Part Number294-2843
UPC810075527445
Weight0.25
