  • PRV Audio WG17-25 1" 60 x 40 Waveguide 1-3/8"-18 TPI
PRV AudioPart # 294-2913
Model: WG17-25
Use the PRV Audio WG17-25 bi-radial horn to create small high efficiency speakers with 1-3/8"-18 TPI screw-on compression drivers. 60° x 40° coverage is perfect for speakers requiring wide horizontal dispersion and narrow vertical dispersion.
  • 60° x 40° dispersion pattern for wide horizontal dispersion
  • 1" throat diameter with 1-3/8"-18 TPI threads
  • Acoustically loads compression drivers down to 1,500 Hz
  • Lightweight ABS construction with bi-radial flare
Your Price: $9.91
MSRP: $12.39
Save $2.48 (20%)
We'll send you an email when PRV Audio WG17-25 1" 60 x 40 Waveguide 1-3/8"-18 TPI is back in stock or available for preorder.
Order in the next 5 hr 36 min to ship today. Details
PRV Audio's WG17-25 60° x 40° bi-radial horn is designed to project an expanded horizontal dispersion while also reducing floor and ceiling bounce. This horn is constructed of durable ABS plastic to keep cabinets as light as possible for easy transport. The standard 1-3/8"-18 TPI threading is compatible with many 1" compression drivers. Acoustic loading is maintained down to 1,500 Hz.
Specifications:• Horn type: Bi-radial • Minimum frequency: 1,500 Hz • Nominal dispersion: 60° H x 40° V • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 5.5" H x 6.25" W x 4" D • Cabinet cutout: 5" H x 4.375" W.
BrandPRV Audio
ModelWG17-25
Part Number294-2913
UPC799928735032
Weight0.25
ConstructionABS
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
