  • PRV Audio TW700Ti-4-SLIM Super Tweeter 4 Ohm Slim Version Pair
PRV AudioPart # 294-3446
Model: TW700Ti-4 SLIM
A slim version of the popular TW700Ti series, the PRV Audio TW700Ti-4 SLIM is a compact, high-performance 4-inch bullet tweeter engineered to deliver exceptional high-frequency clarity in car audio systems. Designed with a slim profile and flat sides for close side-by-side mounting, this tweeter ensures precise sound reproduction in even the most demanding audio systems.
  • Slim design with flat sides for efficient side-by-side mounting
  • Frequency response up to 20,000 Hz for exceptional clarity
  • 105 dB sensitivity for high-output performance with minimal distortion
  • 1.5-inch high-temperature copper voice coil for durability and power handling
  • Built-in capacitor to protect against damaging frequencies at high power
  • Compact size ideal for custom car audio installations
  • Rugged aluminum construction for reliable long-term use
Your Price: $49.91
Save $12.48 (20%)
We'll send you an email when PRV Audio TW700Ti-4-SLIM Super Tweeter 4 Ohm Slim Version Pair is back in stock or available for preorder.
PRV Audio TW700Ti-4 SLIM Pro Audio Super Tweeter Pair
    The 4-inch square high-compression PRO bullet tweeter features flat sides, allowing for close side-by-side mounting. With a high-frequency response reaching up to 20,000 Hz and a sensitivity of 105 dB at 1W/1m, the TW700Ti-4 SLIM is perfectly suited for custom door speaker systems.
    This high-frequency bullet tweeter adds brilliance and articulation to any professional loudspeaker setup, enhancing clarity and detail in your audio.
  • Nominal impedance: 4 Ohm
  • Continuous Program Power (RMS): 210 Watts
  • Program Power: 200 Watts
  • Sensitivity 2.83V at 1m: 105 dB
  • Recommended Hi Pass Crossover**: 5000 Hz**
    **For Full Power Handling  **12db Per Octave Crossover
  • Frequency Response at -10dB: 4,500 – 20,000 Hz
  • Voice Coil Diameter: 1.5” (38 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Former Material: Kapton
  • Diaphragm Material: Aluminum
  • Flux Density: 1.50 T
  • Magnet Material: Ferrite
*Nominal power handling is defined as the maximum RMS power that the speaker can handle in a 2-hour test with a pink noise with 6dB of crest factor and a bandpass filter with 12db/oct tuned in its usable frequency range.
**Continuous Program Power (RMS) is the maximum power that the speaker can handle considering a regular musical program using our recommended filters, this power can be used to define the optimum amplifier power to provide a clean signal without clipping or saturation.
***Max Peak Power is the maximum power operation for the speaker, this power is allowed just for a few fractions of a second, usually found just on the peaks of the music. Keeping this power for a little longer timer will damage the speaker.
  • Overall Depth: 2.28” (57.9 mm)
  • Mounting Depth: 1.89” (48.0 mm)
  • Overall Width: 4.0” (101.6 mm)
  • Overall Height: 4.0” (101.6 mm)
  • Cutout Diameter: 3.70” (94 mm) + Terminals
  • Net Weight: 2.19 lbs (0.99 kg)
BrandPRV Audio
ModelTW700Ti-4 SLIM
Part Number294-3446
UPC810075521054
Unit of MeasurePairs
Weight4.45
Tweeter TypeTitanium
Power Handling (RMS)100 Watts
Impedance4Ω
