CLEARANCE PRV Audio RS12-SUBD4 RS Series 12" Subwoofer DVC 4x4 Ohm
The PRV Audio RS12-SUBD4 is a 12" car subwoofer rated for 1000 Watts RMS, designed to deliver impactful bass in tight spaces without sacrificing performance. It features a dual 4-ohm voice coil setup that lets you configure impedance flexibly for your system. Its compact build makes it ideal for pickup trucks, SUVs, or behind-seat installations.
- Four layer high-temperature copper voice coil built for sustained 1000 Watts RMS power handling
- 17.5 mm Xmax with a high roll surround for deeper bass before distortion
- Side forced cooling and vented back plate enable improved heat dissipation
- Dual 4 Ohm coils allow wiring flexibility and easy impedance matching
- Shallow mounting depth (6.77") makes installation possible in tight or compact enclosures
We'll send you an email when PRV Audio RS12-SUBD4 RS Series 12" Subwoofer DVC 4x4 Ohm is back in stock or available for preorder.
